![]() | Home > Maintenance & Mods (L322) > Replacing front roll bar drop links |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
It's an easy job with just a couple of basic tools required. I take it you are doing both sides? Previously..
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
Yeah will do as they were reasonably priced I got two 2003 Vogue 4.4 V8 Java Black |
Easy job to do yourself no need to even take wheels off. Lock car in off-road height. Lock wheels left or right depending on what side you are doing. It helps to have a bottle jack under the arm to take tension of droplink making it easier to remove one bolts are undone. Just make sure you put washer on correct side take note when removing. Ten minutes a side at most hardest bit undoing nuts |
Have a look here, Pictures 4 and 5
