Home > Maintenance & Mods (L322) > Replacing front roll bar drop links
Tuts
Hi guys, got the clonk from OSF wheel when turning slowly Indy says it's the anti roll bar link, he has quoted 1/2 hour labour to change, was thinking .....it must be easy - do you think I (fairly novice mechanic) could do it? If so what tools are required? Cheers in advance! 2003 Vogue 4.4 V8 Java Black
Post #273135 27th Jul 2014 8:48pm
It's an easy job with just a couple of basic tools required. I take it you are doing both sides? Previously..
Post #273137 27th Jul 2014 8:58pm
Tuts
Yeah will do as they were reasonably priced I got two 2003 Vogue 4.4 V8 Java Black
Post #273140 27th Jul 2014 9:10pm
Googsy
Easy job to do yourself no need to even take wheels off. Lock car in off-road height. Lock wheels left or right depending on what side you are doing. It helps to have a bottle jack under the arm to take tension of droplink making it easier to remove one bolts are undone. Just make sure you put washer on correct side take note when removing. Ten minutes a side at most hardest bit undoing nuts Thumbs Up Buy decent replacements not cheapest as then you won't have to do again for a long time Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #273141 27th Jul 2014 9:18pm
Have a look here, Pictures 4 and 5
http://www.fullfatrr.com/gallery/thumbnails.php?album=359 .
Post #273158 27th Jul 2014 10:38pm
