Home > Technical (L322) > K-Bus Location?
stevenA
2002 Range Rover Vogue Td6 Zermatt Silver
Dan,
In answer to your original question - the rain sensor is the easiest place (behind the rear view mirror) - just make sure that after you remove the mount cover, you displace the mirror connector from its mount and feed the wires back, as otherwise when you twist the mirror to release it, you may damage a sensor wire (as I did!)
Post #58322 2nd Apr 2011 4:44pm
dan_uk_1984
Perfect thanks! I have to take this apart to slip in my new rain & light sensor for my auto-lights upgrade. So may as well have a fiddle whilst I'm in there!
Dan
Post #58338 2nd Apr 2011 5:53pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Dan
Hi Dan
Have you managed to find a LCM 4 for your upgrade, this is the last piece im missing to do my autolight upgrade too.
Matt
Post #58352 2nd Apr 2011 7:35pm
dan_uk_1984
Hi Matt,
I have indeed found a LCM - £50 shipped from the states. God bless the US economy and its weak dollar!
All I have to do now is get my light switch back off Daveo (ahem) and find a rain/light sensor.
I believe I can then use PA soft to recode the Vin & mileage data stored in the LCM?
D
Post #58355 2nd Apr 2011 7:48pm
SteveMFr
Site Sponsor
I've read that as well, but after trying PASoft on different laptops (older w/RS232 and a newer w/2 different usb-serial adapters) I've still never gotten PASoft to connect to the car...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #58376 3rd Apr 2011 6:34am
dan_uk_1984
It was a little tricky to get going initially and equally as difficult to actually use! But I could se it would be quite useful/powerful.
I borrowed it off Daveo a few weeks ago. Might have to borrow it again when this LCM turns up!
Post #58404 3rd Apr 2011 10:08am
Smegordead
United Kingdom 2002 Range Rover Vogue Td6 Buckingham Blue
LCM and Vin Recoding
Hi Guys,
I know this was a log time ago but hoping with your experience you might be able to help.
I want to do the Auto Light upgrade - have the switch and think I've ordered the right sensor but concerned about swapping the LCM and getting a black dot - can they be recoded if they are second hand? if so what software is needed or is a need LCM the way to go and again if so what re-coding is needed?
Thanks 2002 Range Rover Vogue
Post #273634 30th Jul 2014 4:29pm
