Home > Maintenance & Mods (L322) > Recommended a Jack for home Garage /FFRR
JAMIE_M
Mornin' everyone. I'm looking for recommendations for a trolley jack for working on the FF> Nothing serious - hope not to be spending all of my time under it (Naive!)) But something suitable for wheels off for cleaning (Using axle stands of course). So many options on amazon etc. Any advice gratefully received as always
Post #273878 1st Aug 2014 9:05am
any minimum 3 ton weight limit jack will do, good place to look is machine mart or halfords.... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #273880 1st Aug 2014 9:08am
JAMIE_M
thanks stan
sage as always..
Post #273881 1st Aug 2014 9:11am
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
I use a Clarke 3 Tonne lift from machine mart, pretty solid and heavy bit of kit, i'm sure others on here have the same Thumbs Up 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #273882 1st Aug 2014 9:13am
JAMIE_M
this one?
http://www.machinemart.co.uk/shop/product/...-trolley-j
Post #273886 1st Aug 2014 9:16am
jez000
Think mine is this one :
http://www.machinemart.co.uk/shop/product/...l-garage-j
A bit more money but a bit more sturdy Thumbs Up 2021 P400 Silicon Silver AB
Post #273889 1st Aug 2014 9:40am
supershuttle
I was actually looking at axle stands and came across this, I can't make any recommendations as I haven't got one Very Happy
http://www.sgs-engineering.com/hydraulic-j...olley-jack Geoff
Post #273894 1st Aug 2014 10:28am
Stephen.125
2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I use this and it's absolutely belting.
http://www.sgs-engineering.com/tj3lp-low-p...olley-jack
Post #273897 1st Aug 2014 10:45am
i got mine from MM and its the same as jezz's picture..does the job well ... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #273899 1st Aug 2014 11:26am
Given the variety of jobs you will need:
A trolley jack 3 ton +
1-2 bottle jacks 3 ton +
Set Axle stands 3 ton +
1/2 or 1" ply sheets to stand axle stands on, possibly similar for jacks
Variety of blocks of wood (oak preferred Wink)
Never work under the car with just a jack, or when in Off road mode. .
Post #273928 1st Aug 2014 3:46pm
Martin
Site Admin
The "Quick Lift" versions are reported on DISCO3 to fail (twist IIRC) under a D3/4.
Post #273930 1st Aug 2014 3:56pm
I have a BIG PROBLEM with Clarke products, they are cheaply made in China and the quality is not good and when it comes to lifting a heavy vehicle I would rather spend a bit more and get something substantial knowing it will be safe.
My 50 year old Epco 3 tonne trolley jack easily lifts FFRR clean off the ground without any problem.
Don't forget to use good quality axle stands once you have the vehicle raised, again the cheap ones are not up to the weight of the FFRR. I opted for a pair of Draper 12 tonne stands which are tall enough to fit under the back chassis therefore you don't have to worry about the stands sliding off the rear suspension.
If you're lucky enough to have a 4 post ramp in your garage you could always go for a air operated jacking beam, they have all the built in safety features and are perfect for working on suspension areas under the FFRR
Post #273944 1st Aug 2014 6:14pm
Show off Bow down
(dead jealous) .
Post #273965 1st Aug 2014 8:14pm
most of us cant get the FF into our garage let alone have a four poster in there.. Sad ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #273973 1st Aug 2014 9:22pm
Stephen.125
@Martin; for the avoidance of doubt (mine) were you referring to the jack I posted with rapid lift as twisting on D3/D4?
Would be good for me to know as I'm planning a suspension job soon!
Thanks in advance,
Stephen
Post #273975 1st Aug 2014 9:31pm
