Home > Maintenance & Mods (L322) > Recommended a Jack for home Garage /FFRR |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34930 |
any minimum 3 ton weight limit jack will do, good place to look is machine mart or halfords.... ... - .- -.
1st Aug 2014 9:08am |
JAMIE_M Member Since: 01 Apr 2014 Location: South Wales Posts: 9 |
sage as always.. |
1st Aug 2014 9:11am |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 723 |
I use a Clarke 3 Tonne lift from machine mart, pretty solid and heavy bit of kit, i'm sure others on here have the same 2021 P400 Silicon Silver AB
1st Aug 2014 9:13am |
1st Aug 2014 9:16am |
Think mine is this one :
1st Aug 2014 9:40am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3654 |
I was actually looking at axle stands and came across this, I can't make any recommendations as I haven't got one
1st Aug 2014 10:28am |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
I use this and it's absolutely belting.
1st Aug 2014 10:45am |
i got mine from MM and its the same as jezz's picture..does the job well ... ... - .- -.
1st Aug 2014 11:26am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Given the variety of jobs you will need:
1st Aug 2014 3:46pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
The "Quick Lift" versions are reported on DISCO3 to fail (twist IIRC) under a D3/4. |
1st Aug 2014 3:56pm |
I have a BIG PROBLEM with Clarke products, they are cheaply made in China and the quality is not good and when it comes to lifting a heavy vehicle I would rather spend a bit more and get something substantial knowing it will be safe.
1st Aug 2014 6:14pm |
1st Aug 2014 8:14pm |
most of us cant get the FF into our garage let alone have a four poster in there.. ... - .- -.
1st Aug 2014 9:22pm |
@Martin; for the avoidance of doubt (mine) were you referring to the jack I posted with rapid lift as twisting on D3/D4?
1st Aug 2014 9:31pm |
