Home > Maintenance & Mods (L322) > Solar Chargers
TankGunner
England 2002 Range Rover HSE Td6 Epsom Green
Solar Chargers
Hi Guys,
I belive several members use these solar panels to maintain batteries if the vehicle has to stand for some time and connect using one of the cig lighter sockets.Would it be safe to use the OBD2 diagnostic
port for purpose.
Thanks any info gratefully received
TG Life aint no dress rehearsal.
Post #274055 2nd Aug 2014 8:42pm
No you can't use the diagnostic port.
If you don't /can't use an accessory socket or cigarette socket it would be easy enough to wire a solar charger into the passenger side fuseboard or rear fuseboard thro an on/off switch or ignition controlled relay.
Post #274058 2nd Aug 2014 9:04pm
Interesting.....
The lighter sockets are fused and go straight to the battery. I am not sure if the obd port is fused but it probably goes through an ecu of sorts.... Previously..
Post #274059 2nd Aug 2014 9:06pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I would go aux (lighter) socket in the boot or go direct to the battery. The whole area of OBD is complex and best avoided if you can unless there is a specific reason you need to take that route?
I have a Maplin solar charger and whilst it's ok for keeping a perfect battery topped up that's about it, the power output is tiny. 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #274075 2nd Aug 2014 10:21pm
TankGunner
Just that I have a 4amp solar charger that connectsvia the OBD. Used on another vehicle.
Post #274080 2nd Aug 2014 10:46pm
TankGunner
Thaks for the advice.For what they cost I will buy another and use an aux connection Life aint no dress rehearsal.
Post #274119 3rd Aug 2014 2:10pm
RangeK1D
Canada 2004 Range Rover HSE 4.4 V8 Zambezi Silver
What sort of Solar Chargers are a good buy? Are they all Made in China or is there anything manufactured in UK or Germany that's being offered in the market? Zambezi Silver Range Rover (2010 Autobiography Facelift)
Java Black Range Rover 4.2SC (Westminster)
Mercedes Benz GL450 4Matic (X164)
Mercedes Benz E320 CDI (W211)
Mercedes Benz 300SDL (W126)
Lexus LX470 (J100)
Lexus GX470
Audi A8L (D3 Chassis)
Post #274622 6th Aug 2014 8:57am
Brewster
England 2006 Range Rover Vogue SE TDV8 Buckingham Blue
Just to add, as SKOT said you'll have to use the boot socket as this remains "live", the ones in the front are isolated when the ignition is turned off in my experience so it won't charge
cheers ...Always time for a brew !!
2006 TDV8 Vogue SE
Post #276919 21st Aug 2014 1:22pm
