Home > Technical (L322) > Super Charged gearbox woe
Page 2 of 3 <123>
pld118
Hunters LR has said the the car needs a new gearbox and new suspension compressor though Katash (aside to any sweeping generalisations about the competence of the inspecting main dealer)?
The gist of replies here is fairly straightforward though SO3isme:
Decide if the car is to be made good or a refund sought, politely and assertively articulate the concerns in writing without further delay if not already done, return the onus of responsibility to resolve - either way - to the seller, request a courtesy car (or tell the seller if they won't supply a courtesy car you will be left with no option but to hire a modest rental car and will bill them); and once that is clarified in writing, return the RR to the seller pending repair/refund and final resolution within a reasonable and documented timescale.
Post #274137 3rd Aug 2014 6:32pm
SO3isme
Thanks guys for all your posts.
Against my better judgement I took the car to King Automatics in Wimbledon based on the recommendation of Honest John (Telegraph Motoring). They are gearbox specialists. Ken there read the diagnostic fault code as U0102 'Lost communication with transfer box'. He said that he thought is was an electronic issue and that replacing the box would probably make no difference. On the one hand I'm pleased to hear someone say that it doesn't need a new gearbox but on the other it still leaves me wondering where to go next.
I am considering getting the dealer to take the car away and fix it.
As far as the battery goes, there have been no signs of problems. The battery starts the car on the button even after standing for a few days.
Post #274225 4th Aug 2014 12:28pm
Sandyt
Part of the problem is that everything is inside the gearbox but I should have thought it would be possible to get them talking again. Hopefully someone with better knowledge will come along and help
Post #274226 4th Aug 2014 12:51pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
@SO3isme. From personal experience, do NOT touch 3D Transmissions in Reading!! They completely bolloxed up the gearbox on our car when we purchased it - it had a leak on an oil seal and the dealer (non LR) had them recon the gearbox at his cost before we took the car. 4 months later it needed another recondition by TES Transmissions in Westbury and they said , quote " the gearbox looked as if it had been reconditioned by untrained chimps!!
Post #274229 4th Aug 2014 1:14pm
dingg1
"I am considering getting the dealer to take the car away and fix it."
DO NOTHING BUT THIS OR FULL REFUND ,nothing else is acceptable.
you have only had the vehicle six weeks you bought from a dealer the SOGA covers you.
Post #274230 4th Aug 2014 1:16pm
SO3isme
Yes dingg1 - thanks for reinforcing your advice. I have e-mailed the dealer asking him to take the car away and repair it.
Post #274231 4th Aug 2014 1:22pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Shame you don't have an IID Tool .... When my battery was playing up I had gearbox and suspension faults - IID TOOL read lost communication with .... on lots of ecus - classic sign of battery issue apparently
But I'm sure your situation is probably different.
Post #274233 4th Aug 2014 1:30pm
SO3isme
It seems to me that correct diagnosis is 9/10 of the problem.
Post #274234 4th Aug 2014 1:34pm
pld118
Good luck with it all anyway SO3isme,
Keep posting if you want to share the 'what next' stages as you'll get plenty of support and sound advice on this forum.
Post #274238 4th Aug 2014 2:21pm
ebajema
This is a slightly strange one. First I would suggest check battery and alternator. To make sure it's not voltage related.
Next check the gearbox ATF. If that looks okay then start thinking about gearbox issues.
Check my gearbox posts for hints and tips.
Suggest to start with ECU re flash with the latest software, followed by ATF and filter change. Then just the solenoid set and only then a new mechatronic before a full recon. MY 2010 5.0 SC Galway green and sand interior!!
Post #274246 4th Aug 2014 3:17pm
SO3isme
Thanks for this useful sounding advice. Unfortunately, the situation requires a professional garage of some sort to provide the diagnosis, undertake the work and guarantee the result. As above, it really has to go back to supplying dealer to sort out and return fixed.
Post #274248 4th Aug 2014 3:22pm
ebajema
Just let the dealer read the forum, they may save themselves money and time! MY 2010 5.0 SC Galway green and sand interior!!
Post #274249 4th Aug 2014 3:37pm
SO3isme
'not a bad idea. You will note that I have yet to criticise.
Post #274250 4th Aug 2014 3:42pm
Greg66
2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
When the ZF gearbox on our old Audi A8 died, I dug up these guys in Leatherhead, who were highly recommended (somewhere, can't recall where now): http://www.hardyengineering.co.uk
"It needs a new gearbox, Sir" sounds like a very lazy diagnosis to me. Range Rover 4.2 SC
AM V12VS
Porsche 991.1 Turbo S
Mini JCW conv
Post #274252 4th Aug 2014 3:49pm
SO3isme
Thanks Greg, It's good to get a recommendation. The guy I saw this morning has a good reputation as a gearbox specialist. Unfortunately, he felt it was one for a Land Rover specialist! Somebody is wrong somewhere, but as in the above posts in this particular scenario I should not be the one having to do all this running about.
It is hard to fathom the Hunters 'diagnosis'. I am certainly not going to defend them on that point.
Post #274260 4th Aug 2014 4:27pm
Page 2 of 3 <123>
