Home > Maintenance & Mods (L322) > 2010MY key fob refurb |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Can you walk me through it? |
2nd Jul 2014 5:29pm |
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 183 |
Did you manage to get it done wealy?
6th Jul 2014 5:12pm |
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 |
On mine I started by opening up the battery tray and removing it along with the battery, then opened the spare key and working at the end without the release button, used a thin flat bladed screwdriver to start prising the two halves apart. Once you get it started workaround the key onto the top & bottom separate. Be careful of the metal insert which acts as the battery tray side retainer falling out. Take careful note of how all the bits are arranged and proceed to remove the two metal sides and the release button and spring. Reassembly is fiddly 1st go, so take your time and ensure everything is back in its rightful place before snapping the two new halves back together.
7th Jul 2014 4:59am |
Yes - did mine yesterday - quite easy when you know how!!! |
7th Jul 2014 10:31am |
milesg Member Since: 18 Dec 2013 Location: Gloucestershire Posts: 120 |
Did mine this lunchtime, first one took 10 mins, second was a breeze. Looks a million times better and appear to be different / better construction that looks like it will last longer. Appreciate the heads up Flashhart! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
7th Aug 2014 9:42pm |
