Home > Maintenance & Mods (L322) > LED reflector lights
J90
France 2006 Range Rover Vogue Td6 Java Black
I know someone on the forum has fitted these but I cant find the thread:-
http://www.ebay.co.uk/itm/Range-Rover-L322...5409fba11d
Are they difficult to fit? Do you need extra lengths of wire? Is there a particular route to thread the wiring?
Thanks all. Travelling around in circles again.
Post #274907 7th Aug 2014 11:29pm
pld118
http://www.fullfatrr.com/forum/topic24379....+reflector
Post #274919 8th Aug 2014 4:20am
J90
Thanks for the link pld. Thumbs Up Travelling around in circles again.
Post #274938 8th Aug 2014 9:54am
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
Led reflector lights
Don't waste your money. They are crap . Look good but are very poor quality my first set lasted 4 days before they went faulty &. Stop lamps stayed on with tail light Supplier sent replacements they lasted 8 days. One stopped working other one kept flickering. . Complete waste of money. They ended up in the bin Big Cry
Post #274940 8th Aug 2014 10:40am
J90
Oh, I was quite keen on fitting them. If two pairs have failed I wont bother. Ta for the info. Travelling around in circles again.
Post #275004 8th Aug 2014 8:24pm
They aren't that crap. Whistle Laughing
I have some fitted and working fine.
I should point out that whatever the seller says they are not a straightforward fit in terms of electrical connections.
I found that to make them work reliably, particularly with the brake lights it was necessary to feed each of the two circuits thro independent relays.
I have a 12 volt supply from the rear fuseboard supplying the contacts on the two relays.
One relay coil is fed from an ignition source so that the leds are on "low" all the time the ignition is on.
The other relay coil is fed from the brake circuit so that the leds go to "high" when the brakes are applied.
You could also chose to have one of the relays controlled via the sidelight circuit.
If you don't feed them independently thro relays the brake light function of the reflectors results in the cars brake lights "locking on" together with the leds when the ignition key is removed.
This fault seems to be something to do with the leds being fed from two 12V sources simultaneously to obtain "high" and "low" as advised by the seller. Might only be peculiar to RR's, I've no idea, but using relays definitely solves the problem.
Whether you like them or not is down to personal choice.
Post #275012 8th Aug 2014 9:10pm
craig has these fitted and they looked very nice when i saw them.. ... - .- -.
Post #275016 8th Aug 2014 9:16pm
And the original:
http://www.fullfatrr.com/forum/topic13965.html?highlight=rear+drl
Wink .
Post #275019 8th Aug 2014 9:23pm
pld118
All seems very complicated!
Post #275020 8th Aug 2014 9:24pm
