![]() | Home > In Car Electronics (L322) > Dash Camera Loop setting |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35775 ![]() ![]() |
have a look at this video ,i'm sure he explains the loop bit..
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 ![]() ![]() ![]() |
Stan,
sounds like a plan. |
It's a good job I didn't buy from China .
did you buy from joovuu? ... - .- -.
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Look at dash cam uk forum,, what firmware do you have as there have been issues, mine been the older 0801 I had to do 2 firmware upgrades for it to work successfully and now has been reliable for months. If it dont work.......burn it!
I didn't buy from JooVuu after reading some comments on the dash forum. I take it that you have had no problems with them in the past? |
Forgive ones ignorance but I am none the wiser with regard your question re firmware. It would appear that a possible solution will be to turn off Motion Sensor and reformat. I'm sure that it is an easy fix and will persevere. |
this might be of interest to you,
Much appreciated Stan. I'd already had a quick read of the forum you mentioned following Welsh Dragon's message above. I'm only glad that other people have had the same problem.
you're welcome. |
