Home > In Car Electronics (L322) > Dash Camera Loop setting
silversurfer
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
I've recently fitted an 0803 dash camera that now does not overwrite when the SD card is full. The sign "Card Full "being displayed in the middle of the screen in red. I was led to understand that the recording was automatically done in a loop .I have manually deleted (formatted) all previous recordings ,but have I missed something with regard to setting up /installing Question Within the camera menu a loop setting mode does not exist although reference is made to it on some articles that I have read.
I would appreciate any help/advice .
Many Thanks.
Post #275234 10th Aug 2014 9:15pm
have a look at this video ,i'm sure he explains the loop bit..
Post #275236 10th Aug 2014 9:16pm
silversurfer
Stan,
Thanks for the swift reply. I have watched that excellent video several times and reference is made to over recording as being automatic. As shown using the coloured car models in the beginning of the video.
In a user guide link to the 0803 , reference was made to loop setting ,but as can be seen quite clearly in the video mentioned above no such setting appears in the camera menu.
I'll use the default settings once more and if all fails get a replacement.
Overall it's a great camera and the play back quality is absolutely top notch.
Post #275243 10th Aug 2014 9:46pm
sounds like a plan. Thumbs Up ... - .- -.
Post #275245 10th Aug 2014 9:52pm
silversurfer
It's a good job I didn't buy from China .
Think of the postage.
Post #275248 10th Aug 2014 9:57pm
did you buy from joovuu? ... - .- -.
Post #275251 10th Aug 2014 9:58pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Look at dash cam uk forum,, what firmware do you have as there have been issues, mine been the older 0801 I had to do 2 firmware upgrades for it to work successfully and now has been reliable for months. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #275259 10th Aug 2014 10:16pm
silversurfer
I didn't buy from JooVuu after reading some comments on the dash forum. I take it that you have had no problems with them in the past?
Post #275292 11th Aug 2014 9:42am
silversurfer
Forgive ones ignorance but I am none the wiser with regard your question re firmware.
It would appear that a possible solution will be to turn off Motion Sensor and reformat.
I'm sure that it is an easy fix and will persevere.
Post #275293 11th Aug 2014 9:47am
this might be of interest to you,
http://forum.dashcamtalk.com/threads/recycling-problem.6532/
and this,
http://forum.dashcamtalk.com/threads/am-i-...ease.5678/ ... - .- -.
Post #275294 11th Aug 2014 9:52am
silversurfer
Much appreciated Stan. I'd already had a quick read of the forum you mentioned following Welsh Dragon's message above. I'm only glad that other people have had the same problem.
All I have to do now is fill the card up and see what happens .Any old excuse to take the old girl out for a spin(long one)
Once again many thanks for your help. Thumbs Up
Post #275326 11th Aug 2014 2:03pm
you're welcome. Thumbs Up ... - .- -.
Post #275330 11th Aug 2014 2:34pm
