![]() | Home > Maintenance & Mods (L322) > Errors in Everything HELP |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
battery? will be the first thing to check. Happened to me with the Disco3 and the Fattie that when the battery is on its way out it gives all kinds of messages.
New battery, make sure you fit the correct one |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16400 ![]() ![]() ![]() |
As above, battery |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Much thanks.
Stroker Member Since: 03 Jul 2012 Location: Switzerland Posts: 3 ![]() ![]() ![]() |
maybe a faulty reardifflock actuator. |
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 ![]() ![]() |
Also check that if you push the brake pedal very hard that it does not do it. Faulty brake pressure switch can set off everything as well. 2011 Stornaway Grey 5.0SC Autobiography |
^ & ^^ Thank you. I'll add to the (long) list of suspects... |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 173 ![]() ![]() ![]() |
I've got identical faults on a TDV8.
The reason the brake switch causes so many issues are that the brakes are where the ABS sensors are... which affect height, transmission, ABS and a whole host of other electrical signals. 2011 Stornaway Grey 5.0SC Autobiography |
I hadn't abandoned the thread, just waiting until I had a solution to update the forum.
Thanks Jonlewis and rr2008hse.
Wow, that sounds very frustrating.
SO3isme Member Since: 18 May 2014 Location: Woking Posts: 110 ![]() ![]() ![]() |
Have all the fault codes been properly cleared after the work? |
Yup the fault codes all cleared. Battery terminals are fine.
