|  | Home > Maintenance & Mods (L322) > Errors in Everything HELP |
| vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390      | battery?  will be the first thing to check.  Happened to me with the Disco3 and the Fattie that when the battery is on its way out it gives all kinds of messages.
|  13th Aug 2014 6:02am |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | New battery, make sure you fit the correct one   | ||
|  13th Aug 2014 6:18am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | As above, battery  | ||
|  13th Aug 2014 9:00am |
| RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932      | Much thanks.
|  13th Aug 2014 3:08pm |
| Stroker Member Since: 03 Jul 2012 Location: Switzerland Posts: 3      | maybe a faulty reardifflock actuator.  | ||
|  18th Aug 2014 8:57pm |
| jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308    | Also check that if you push the brake pedal very hard that it does not do it. Faulty brake pressure switch can set off everything as well. 2011 Stornaway Grey 5.0SC Autobiography | ||
|  18th Aug 2014 9:04pm |
| RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932      | ^ & ^^ Thank you. I'll add to the (long) list of suspects... | ||
|  19th Aug 2014 12:17am |
| Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 173      | I've got identical faults on a TDV8.
|  23rd Aug 2014 5:43pm |
| jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308    | The reason the brake switch causes so many issues are that the brakes are where the ABS sensors are... which affect height, transmission, ABS and a whole host of other electrical signals. 2011 Stornaway Grey 5.0SC Autobiography | ||
|  23rd Aug 2014 6:08pm |
| RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932      | I hadn't abandoned the thread, just waiting until I had a solution to update the forum.
|  24th Aug 2014 8:05pm |
| Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 173      | Thanks Jonlewis and rr2008hse.
|  25th Aug 2014 2:52am |
| RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932      | Wow, that sounds very frustrating.
|  25th Aug 2014 3:31am |
| SO3isme Member Since: 18 May 2014 Location: Woking Posts: 110      | Have all the fault codes been properly cleared after the work? | ||
|  25th Aug 2014 7:27am |
| Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 173      | Yup the fault codes all cleared. Battery terminals are fine.
|  26th Aug 2014 8:04am |
| Posting Rules
   well sort the problem!
 well sort the problem! )
