![]() | Home > Technical (L322) > Ignition key turns then 'click' - no start |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
Had a call from my wife yesterday, she thinks our RR's 'Drain your Bank Account' chip has gone off again |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 ![]() ![]() ![]() |
I had this once and (I'm not joking here) it was because it was in drive |
Wife booked the car in for next week, the dealers suspect the starter motor, which, if that is correct, its only lasted a year!! |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
My car has done this consistently over a two year period without any problems. I've never given it a second thought as it always starts second turn. |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
I had this a while back - turn the key and a 'click' - intermittently - retry and it started.
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 ![]() ![]() |
Just had the wife call saying she has had the no start issue again after a year off. It's a 110 battery, new alternator and regularly used. The rac said he had never seen a battery with only 2% charge which was regularly used. He said it is normally a relay that stays open but diagnostics would not show it up. It is only apparent when it is playing up.
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 ![]() ![]() |
Had something similar myself recently which turned out to be the positive connection on the battery had risen up so was intermittent on giving a full belt of power.
Strangely she said initially the radio, etc worked then park brake fault/release park brake message (or something like that) then everything went dead... '96 Volkswagen Polo 1.4CL - SOLD
I also had the radio switch itself off a couple of times and a random fault or two, so certainly worth a look. 2011 Stornaway Grey 5.0SC Autobiography |
Got the car back yesterday, they could not find anything wrong with the switch or starter motor, BUT the battery was not the correct one for the car, it was down by 100amps!
Glad it got sorted. Batteries rarely fail but sometimes do. I just put my second Yuasa in the B-King, not sure if it was a drain or not. Since my battery tender lead came in this week it is now hooked up permanently |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Interestingly I had a similar issue on my old p38 range rover and I eventually traced it to the cable from the alternator to the starter had internal corrosion and the first try when it clicked moved the cable and effected a circuit and over time it would settle in a position with not enough circuit cured by putting new lead in £6 from local factors so might be worth seeing what is being delivered at the battery not what is being produced by the alternator |
