Home > Off Topic > Return flights vs One Way
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Alistair wrote:
http://www.britishairways.com/en-gb/inform...f-carriage
Section 3C
If you tell them in advance - and they agree - they may charge you a revised fare - which I guess could be zero, but then again, might not be.....
Or knowing BA they would probably charge you the one way fare plus a change fee. No problem with not using the return leg of a flight and I have done it many time for various reasons but would not risk not taking the first leg. In this circumstance what I normally do is book my main flight to a region as a return and then buy side tickets for local flights, especially where plans are not fixed and then if necessary and depending on ticket basis pay to change the return date if I need to. Do check the fare basis of any ticket you buy if changes are likely as some are non changeable and other have large fees so often better to buy a more flexible fare basis in whatever class you are buying.
I would personally look to buy a London to Hong Kong return with your chosen airline, (I would personally avoid BA) and then a return from Hong Kong to Toyko. Alternatively you may be able to buy as a single ticket London - Hong Kong - Tokyo - London (may have stopover/plane changes) with someone like Cathay Pacific of Japan Airlines. BA & Virgin will nearly always be the most expensive options unless on a package or very cheap economy ticket based on 20+ years of short and long haul business travel. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #276280 18th Aug 2014 10:46am
Quantas used to do a cheap multi stop return ticket?
Still do...
http://www.qantas.com.au/travel/airlines/m.../global/en
Post #276281 18th Aug 2014 10:49am
rej
Star Alliance network does a round the world ticket that allows multiple stops but you have to keep going in the same direction for the best price and there used to be a 10 day minimum trip duration. There is a difference between knowing your sh!t and knowing you're sh!t
Post #276285 18th Aug 2014 11:35am
I used the Quantas Multi Ticket to go all the way round the world with 12 stops for £1500 back in 1990!
Post #276290 18th Aug 2014 12:12pm
recordman
United Kingdom 2017 Range Rover Autobiography SDV8 Aruba
You could do far worse than to speak to a decent travel agent like Trailfinders. They've sorted me out with many complex tickets in the past and no credit card charges either.
Post #276309 18th Aug 2014 1:55pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Thanks for all the advice folks.
I'm tied to using the work preferred agent and will get "discounted" rates (that are probably higher than normal) through work so can't go booking anywhere else.
Was just wondering on my options to ask them to book... Will see where it takes me... Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #276338 18th Aug 2014 6:38pm
recordman
Depending on whether your company's preferred agent is 'creative' enough and you can tolerate a bit of inconvenience, but great savings can be made by starting journeys from European airports rather than the UK still using BA and OneWorld airlines.
There's a wealth of information here from hard core travellers. Keep you busy for ages!
http://www.flyertalk.com/forum/british-air...hread.html
Post #276356 18th Aug 2014 7:13pm
