Home > Technical (L322) > Brake pad wear indicator lead ?
Shandonman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
I take it that is what this is. I was under the car fixing the parking sensors and saw this
It is just hanging down but looks like it attaches somehow to the caliper. Does anyone know, if I order a new lead, is it fairly simple to fit. I can't see properly where the other end connects ? 2002 Vogue 4.4 V8
1995 Disco 1 300tdi
Post #277137 22nd Aug 2014 4:44pm
this is from the 2006-2009 WM but it might give you an idea..[couldnt find anything in your year WM]
Post #277143 22nd Aug 2014 6:04pm
Break pad wear indicator lead, clips into a groove on the pads, seems to have been left off.......
 There is nothing that can't be fixed with a hammer😜😜
Post #277241 23rd Aug 2014 5:18pm
RRPhil
Worn (warning light on) :
New :
Phil
Post #277258 23rd Aug 2014 8:12pm
Shandonman
Thanks for the brilliant pics, shows exactly how they are fitted & work. Ordered new pads & lead
Presumably no warning light as it needs to earth to light up 2002 Vogue 4.4 V8
1995 Disco 1 300tdi
Post #277261 23rd Aug 2014 9:10pm
Exactly, wears to the contact, then light comes on. There is nothing that can't be fixed with a hammer😜😜
Post #277262 23rd Aug 2014 9:27pm
ahebron
New Zealand
My 2003 TD6 has 2 wire sensors so I assume it is a closed circuit that once the sensor has worn becomes open circuit and maybe goes to earth as well though the disc.
But mine has the rear one hanging loose and the light is on. All pads are ok and fluid is fine.
Adrian VW Amarok 2014 Highline auto
Post #277643 27th Aug 2014 8:04am
ahebron
New Zealand
As today was such a lovely I thought sod it let's replace the rear brake pad west sensor after work.
So I did.
Now this is the interesting bit. After replacing the sensor and lead I put a meter across the old one and I metered ok, by that I mean the circuit was complete across both pins. So why did the new one work and the old one fail, admittedly I didn't test the the new one to see what it read on the meter.
Post #277848 28th Aug 2014 11:42am
