Home > Technical (L322) > Transmission problems
Page 1 of 3 123>
Netvet
United Kingdom 2006 Range Rover Vogue 4.4 V8 Java Black
Hi there everyone I have a 2006 rr 4.4 vogue
I was driving down a duel carriageway and the transmission started to slip and flashed up limited gears available
I had no choice but to ease off and carry on to a safe place to stop
Upon stopping did smell a bit burnt and then was unable to select gears would indicate gear but not engage
Called recovery tech guy came out first said possible torque converter failure he revved engine and heard a big high pitched squeak
Read the fault codes next day came up with 5th gear and 6th gear incorrect ratio and transmission overheat.
Removed sump pan and quite obvious metal debris but seems fresh debris if u understand what I mean
I'm not an auto expert and any help would be much appreciated thanks in advance
Post #277443 25th Aug 2014 9:50pm
I'm not an auto expert either, but my guess is an auto expert would tell you your gearbox is f*cked. Sad
Post #277448 25th Aug 2014 10:26pm
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
hello mate, sorry to hear your news. this post has had 26 views and not one "welcome".
so firstly hello!
I'm newbie to the FF, however a quick search on here will give lots of possible indications. however some will need more info to help a diagnosis.
how many miles has your FF done? what's the service record like and when was the gearbox last serviced? have there been any issues leading up to this such as slipping on inclines etc?
I'm sure someone will be along with some possibilities.
in the meantime read the searches on here re the FF weak point.
jake 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #277450 25th Aug 2014 10:32pm
Netvet
I kinda gathered that lol after solutions please rebuild costs or whether parts are available and where to source them from
Possible causes For example would the torque converter failing throw the debris into the box and would just cleaning box out fix it or if anyone knows anyone that rebuilds them as a hobby.
How do you even tell if the torque converter failed ?? Stuff like that thanks
Post #277451 25th Aug 2014 10:37pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Welcome.
Just to be clear, you're vehicle is a 2006 Model Year with the Ford / Jaguar 4.4 V8 and 6 speed ZF 6HP26 gearbox?
(As opposed to the BMW 4.4 V8 + 5 speed gearbox) 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #277452 25th Aug 2014 10:38pm
Netvet
Hi jake thanks for the welcome the rr got full dealer history mileage is a whopping 184000 now I'm just going though it all to find when box was last touched not had any problems before she's never towed anything from new
Post #277453 25th Aug 2014 10:41pm
Netvet
Hi skot yes that is correct she has the six speed box in
Post #277454 25th Aug 2014 10:42pm
Embarassed Welcome NetVet.
This thread may be helpfull.
Post #277455 25th Aug 2014 10:43pm
Netvet
Kurtverbose
Amazing just what I was looking for Very Happy
Thanks for the welcome [/quote]
Post #277456 25th Aug 2014 10:46pm
SKOT
OK, lots on here about gearboxes:
TD6 with the GM 5 speed
4.4 V8 (BMW) with the ZF 5 speed
Both of which have their issues but are a totally different configuration to you car so don't let this lead you down the wrong path. The ZF 6 speed to date has been relatively problem free although with some time and miles some bits and bobs are appearing. Evil or Very Mad
Maybe worth calling A1 Transmissions tomorrow. Their car park is full of 4x4s, many are Land Rover products. It's worth a call to see what they say although I guess they will just want to throw a recon gearbox at it..... Big Cry
Good luck with it. Let us know how you get on. 2006 4.2 SC
Post #277457 25th Aug 2014 10:49pm
jakebullet64
Hi mate. RRphil is the transmission God on here Bow down
maybe a quick pm might give you some answers?
Jake 2003 Range Rover Vogue 4.4 on Gas
Post #277458 25th Aug 2014 10:54pm
Netvet
Thanks skot she's defo got a lot of miles on her 184000 my dad bought it brand new so it's gotta be fixed as its got loads of memory's for him
Would like to rebuild the original box if possible
Post #277459 25th Aug 2014 10:55pm
Netvet
Hi jake just reading his write up now on the six speed box will pm him after I've read it thanks again Thumbs Up
Post #277461 25th Aug 2014 10:58pm
Netvet
Bit of an update got bored of people quoting mega money so
Stripped the box tonight and I found that clutch B as in rrphil strip down info had bad friction plates
So much that the casing has eaten into box
Just wondering if it would be ok to replace the friction plates and rebuild or would it need new casing
Thanks
Post #277584 26th Aug 2014 8:05pm
RRPhil
Could you post some photos of the damage?
There are 7 official ZF part suppliers in the UK : http://www.zf.com/eu/content/en/great_brit...rs_uk.html
but I may be able to help out.
Phil
Post #277588 26th Aug 2014 8:37pm
Page 1 of 3 123>
