Home > Other Site Sponsors > New firmware & app release, V3.0, for the IIDTool...
Page 3 of 7 <1234567>
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
fanders : One could do it manually when the export functionality of the live values becomes available. As far as adding it to the App itself, we will have to think about it when we have a bit more free time.
shalz : already replied to your mail. Thumbs Up
Post #272412 23rd Jul 2014 6:06pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Just a quick thumbs up for the guys at GAP. Just got a none BT tool but ran into problems after updating to version 3. Email to them today (Saturday) and an email back from them with a fix (new download) within a couple of hours. All sorted and well impressed with the service. Thumbs Up Cheers Guys
RP
Post #272923 26th Jul 2014 3:53pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
What additional update software is added to the NON BT IId tool V3 from the 2.7? Any benefit to updating? If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #272945 26th Jul 2014 6:27pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
New IID user
Just bought the BT version of the IID tool and have turned off the TPMS system - a bit scary, but fun!
The FF is running great, there were a few fault codes stored so I cleared them and will see if any recur. Is there anything like a 'normal' number of error codes, or should one be aiming at zero?
Thumbs up to the IID guys! Thumbs Up
Fanders
Post #274484 5th Aug 2014 7:21pm
You can aim for zero, but the chances are slim! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #274486 5th Aug 2014 7:27pm
you wont get zero, the tpms will show up as four faults even though you have switched it off, but dont worry about that one.. ... - .- -.
Post #274489 5th Aug 2014 7:40pm
fanders
Post #274533 5th Aug 2014 8:56pm
Weegie
87RJD wrote:
OK Stan, so I see others have done it, I'll re word my question, has anyone else had E5 error message while doing the upgrade to the BT ECU, if you have, what did it mean?
Thanks
Did anyone ever find an answer to this?
My 2004 (MY 2005) recognises my phone, a Samsung Galaxy S4, and pairs without any apparent problem. However, when I make a call it rings but when the other end picks up it immediately disconnects and the message "Call Ended" appears.
I have tried re-flashing the ECU using the iiD Tool (BT) but, although it starts the process and indicates 41 minutes duration, after about a minute or less it says that the re-flash has failed. I have tried a couple of times but still no joy and I also have had the E05 message showing.
Anyone any ideas or pointers, please? John
GAP iiD BT-Sold
Post #277719 27th Aug 2014 2:57pm
ebajema
For the Faultmate, they recommend to put a battery charger on the car while doing a re-flash to ensure that the voltage stays high and constant. Maybe worth giving that a try if you haven't done that yet. MY 2010 5.0 SC Galway green and sand interior!!
Post #277720 27th Aug 2014 3:11pm
Weegie
Thanks for that. GAP also recommend the same but say that, if the battery has a good charge, it wouldn't be necessary.
My battery is well up and I had just returned from a run but will give it a try later.
Thanks again for the reply. Thumbs Up John
GAP iiD BT-Sold
Post #277721 27th Aug 2014 3:21pm
Weegie
An update. Contacted GAP support and Patrick, once again, came good. Downloaded Beta firmware and Tel ECU Flash worked a treat. Recognises my Samsung S4 GT-19505 and full access to the phonebook.
Happy Bunny.
Great support. Thumbs Up John
GAP iiD BT-Sold
Post #277916 28th Aug 2014 7:24pm
daveo
just updated my one but still sitting at 2.17 Shocked V8 facelift Range Rover Autobiography 22" wheels.
Post #277931 28th Aug 2014 9:17pm
clarkie
England 2005 Range Rover Vogue Td6 Adriatic Blue
Daveo, same here but i have the non bluetooth version.the question has been ask a few time when the non bt units are going to be upgraded and has been ignored by the gap people on here. even if the answer is its not going to be done.
Post #278295 31st Aug 2014 12:10pm
The update for none BT units is out for Beta users so not long now . 2008 MY Supercharged
Post #278298 31st Aug 2014 12:13pm
clarkie
thanks for the info axle.thats more than has been said by the gap bods
Post #278509 1st Sep 2014 6:41pm
