Home > Technical (L322) > Yet another efing problem vibration through car :update
Page 3 of 4 <1234>
How much movement in mm is there top to bottom of tyre, at the tyre edge?? Pete
-Click here for Thread-
Post #277234 23rd Aug 2014 3:37pm
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
Hard to tell poss 2-4 mm not much more and that's with car on ground you can feel movement but can't see where it's coming from.
Thinking wheel bearing . Could do with some one to look at it all the indies near me can't or won't look at it till mid sept any one not to far from Stockport want to have a look don't mind coming to you have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #277235 23rd Aug 2014 3:43pm
trainmanone
the vibration can be felt through the car not so much through the steering wheel although there is a slight feel.
the boss woman says its not like going over a cattle grid.
would a wheel bearing give this vibration ????? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #277286 24th Aug 2014 10:18am
That's a difficult question, wheel bearings usually get worse when you turn one way or another....
You won't find play in anything unless you jack the wheel off the ground and let it hang free, then try a prybar against the balljoints or bushes
Make sure it's on axle stands before you get at it with a pry bar or you may pull it off the jack....
Did you have this vibration before you had the work done you mentioned in your first post?? Pete
Post #277287 24th Aug 2014 10:44am
trainmanone
hi Pete yes was getting vibration at 55 -65 ish on long left hand bends, but defo movement in n/s wheel when you push top of tyre there's a thud not loud more feel the thud if you know what I mean ,like when you put wheel on hub have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #277288 24th Aug 2014 10:52am
Is the vibration through the steering wheel or through the car, i.e does the steering wheel shake or does your seat shake!!?? Pete
Post #277305 24th Aug 2014 5:24pm
trainmanone
Have posted that above mainly through seat and floor now but originally through the steering wheel . Going to change bottom arm tomorrow for a known good one and see how that goes have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #277308 24th Aug 2014 5:48pm
I know you have already had them done but get the wheels balanced again, I have had this more than once that they don't do them properly, if they don't get pulled up square on the machine then they will be wrong, take it somewhere else and ask them to check them without removing the weights that are on there and see how far they are out, anything over 20grams, ask them to re balance them. I find small independants tent to help more if you explain why....
Don't think the bottom arm would give your exact symptoms... But you never know!!!
Good luck Pete
Post #277318 24th Aug 2014 6:28pm
trainmanone
hi Pete,
this is where we are up to now, around Feb./march this year noticed a quite bad vibration on long sweeping left hand turns at 55-65 mph with power on take foot of gas it went, didn't have time to sort it ,vibration through the steering wheel and floor
mot in June nothing mentioned apart advisory about ball joint on o/s front.
I had all lower arms on n/s done last year and all lower arms on o/s done after mot, still vibration on long left handers
had new tyres balanced all round vibration still on left handers
took for full geometry set up now vibration left, straight and right at 55-65 mph
vibration through the floor mainly now
also very slight play top of n/s wheel moves in towards car when pushed not by more than a couple of mm you get a thud can feel the thud but can hear it as well (sort of like fridge door shutting)
seams as though having geometry done has brought the vibration round from the left as once you take foot of gas it goes
really getting Censored off with it now
Pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #277490 26th Aug 2014 9:48am
Yep.... that doesn't seem an easy one, think I'd just start replacing stuff as well.... just start with the cheapest...
Have the bottom arms been done properly and the bolts tightened up with the full weight of the car on them??
Check tyre pressures, engine, box, exhaust mounts....
Just trying to think of all the free things to try first... Pete
Post #277537 26th Aug 2014 2:20pm
trainmanone
going to replace n/s control arms it had the ball joint done three weeks ago so know for sure the n/s will be newly done se where we go from there
pressure is off me as have hired car for picking family up from Heathrow on sat at one am
but will get it sorted with the forums help or I will burn the Censored lol have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #277541 26th Aug 2014 2:27pm
trainmanone
just found this on the net,
Along with a rumbling sound, bad wheel bearings may also make a vibration that can be felt in the car or in the steering wheel. This vibration may become worse at higher speeds, when turning or braking.
Read more : http://www.ehow.com/facts_7270680_do-wheel...like_.html
haven't got any rumbling noise as such but think poss the problem have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #277619 26th Aug 2014 10:49pm
trainmanone
hi gang having sat and thought about it for a while ,now thinking cv joint and wheel bearing ,here's the reasoning behind it.
can here a slight clicking not loud though
early last year wheel bearing needed doing on n/s front a mate fitted a second hand hub ,I thought he had put a new bearing in it after a phone conversation last night transpires hi fitted new bearing to rear n/s
then on prepping for 2013 mot (June) noticed cv gator had split all round had that and n/s control arms replaced.
so as you can see both bearing and cv joint could be f£$%^&&ed
what do you think have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #277745 27th Aug 2014 5:53pm
Well it shouldn't click, even if it isn't loud....
Have you tried it on full lock with the window down?? Pete
Post #277765 27th Aug 2014 7:31pm
trainmanone
that's what im saying its a slight click consistent withn what speed im doing same on full lock left and right.
cant do anything
on car as my back has started to play up now Sad
just trying to figure things out in my head at moment
but the more I think of it the more it loos like the problem have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #277772 27th Aug 2014 7:58pm
Page 3 of 4 <1234>
