Home > Maintenance & Mods (L322) > Help required. Should I start it?
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Hi Guys
Came home tonight to the Rangie in the weeds, well below access IMHO. I was jut going to jump in and start it.... should I or could that be detrimental, it knows its MOT is due in 2 weeks... spooky Thumbs Up
Post #278053 29th Aug 2014 5:53pm
Rosco
Oops picture would be good Whistle
Post #278055 29th Aug 2014 5:57pm
That looks ominous. Confused
Post #278060 29th Aug 2014 6:19pm
Rosco
Cheers nicedayforit, as I said, MOT in 2 weeks, too much of a good thing etc..... Looking on the bright side it has only cost me tyres and servicing this year!! Although £4500 for last years MOT was a tad annoying, compressor was the year before so out of warranty, I love my RR Whistle
Post #278062 29th Aug 2014 6:28pm
One way to find out how expensive it's going to be....start it and see what happens. Thumbs Up
Post #278067 29th Aug 2014 6:36pm
Rosco
Off to start the Censored Thumbs Up
Post #278068 29th Aug 2014 6:38pm
Rosco
Happily moved back to normal mode but wont move up or down from there !! At least I can tow this weekend then I am sure Mr MOTman will relieve me of some beer vouchers Thumbs Up
Post #278073 29th Aug 2014 7:18pm
mjdronfield
If it stays up with no errors and leaks during the mot you will be fine.
Depends how quickly the air leaks out........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #278078 29th Aug 2014 7:32pm
Errr...
Testing the various suspension joints etc for play requires the car to be put in to off-road height so that it can be jacked up and subsequently removed from the jack.
If the car can't be raised to off-road height it could well be a fail unfortunately. Sad
You did have all the doors closed when you tried to raise it I suppose?
Post #278083 29th Aug 2014 7:48pm
mjdronfield
Never done that with mine over the 3 mots I've had done.
Goes on 4 post lift and then they jack the front wheels up on the lift jack.
Rest done in situ. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #278084 29th Aug 2014 7:52pm
That's interesting, they do it everytime I go for an mot.
The problem is getting the car off the lift jack. If you leave it in on-road height and lower the car after jacking the jack can't be lowered sufficiently for the it to clear. Mine got stuck on the jack the first time I took it. Next time they read the instructions that are dispatched when an L322 is logged in on the computer, no problems since.
Post #278087 29th Aug 2014 8:17pm
mjdronfield
Don't know then mate. Have to see how you get on..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #278089 29th Aug 2014 8:28pm
johnboyairey
make sure your doors are well shut, and bonnet and tailgates it could be a leaky 'bag, and its trying to settle/even up and found its bottom on the floor. -if you get it up on MOT mans ramp and he does't mind. (ie after testing, waiting for paperwork. you could paint the airbags seals with fairy liquid soapy water, to see if its an obvious leak. put car in offroad, takes 10mins max. Some people find standing under a two ton lampshade a bit imposing though.
Post #278167 30th Aug 2014 12:54pm
If the system detect the pressure is dropping too quickly (i.e. a leak) it will often shut down (hence the lights going off) it closes valves and contains as much pressure as it can to get you home... Thumbs Up
I certainly would not use the car like it let alone tow with the car! Shocked
Post #278171 30th Aug 2014 1:13pm
