![]() | Home > Maintenance & Mods (L322) > Help required. Should I start it? |
| Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591
Oops picture would be good |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
That looks ominous. |
Cheers nicedayforit, as I said, MOT in 2 weeks, too much of a good thing etc..... Looking on the bright side it has only cost me tyres and servicing this year!! Although £4500 for last years MOT was a tad annoying, compressor was the year before so out of warranty, I love my RR |
One way to find out how expensive it's going to be....start it and see what happens. |
Off to start the |
Happily moved back to normal mode but wont move up or down from there !! At least I can tow this weekend then I am sure Mr MOTman will relieve me of some beer vouchers |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
If it stays up with no errors and leaks during the mot you will be fine.
Errr...
Never done that with mine over the 3 mots I've had done.
That's interesting, they do it everytime I go for an mot.
Don't know then mate. Have to see how you get on..... 2011 Range Rover Vogue SE 4.4 TDV8
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
make sure your doors are well shut, and bonnet and tailgates it could be a leaky 'bag, and its trying to settle/even up and found its bottom on the floor. -if you get it up on MOT mans ramp and he does't mind. (ie after testing, waiting for paperwork. you could paint the airbags seals with fairy liquid soapy water, to see if its an obvious leak. put car in offroad, takes 10mins max. Some people find standing under a two ton lampshade a bit imposing though. |
If the system detect the pressure is dropping too quickly (i.e. a leak) it will often shut down (hence the lights going off) it closes valves and contains as much pressure as it can to get you home... |
| All times are GMT |
