![]() | Home > Maintenance & Mods (L322) > AIR SUSPENSION INACTIVE!! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8722 ![]() ![]() ![]() |
Sure it wasn't, no voltage FROM the height sensor, that would just mean it needs a new sensor, if it's no voltage to, then I would think it would be a broken wire somewhere
Plumber cae Member Since: 19 Jun 2014 Location: Blackwood Posts: 21 ![]() ![]() ![]() |
Cheers for the reply Pete. It was TOO and that was the new sensor I put on, I know but I don't know which tool to get?? The hawke or lynx |
Personally neither, I'd get the IID tool it works great.... cheapest is here
Just had a look, it says it uses the dashboard screen does it mean the sat nav or those under the clocks? If it's the clock screen then I have another job to do before I buy it!! Fixing the pixelated screen lol!!! |
Right, just got under it and found a load of insulation tape wrapped around the height sensor wire near the plug, removed it and found 1 wire just hanging there and another bare with solder on it which goes into the plug looks like the hanging wire has come from the solder. I'm guessing this is not the correct way LR had originally done it. Does anyone have a wiring diagram of these plugs please. |
Here you go. Sorry about the quality, something to do with uploading to this site.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
From wiki
Cheers guys real help, I got your emails thank you David, just bought myself the iid, pixel fix ribbon and height sensor repair plug. Will let you know how I get on!! |
Pixel fix ribbon is the hard one apparently... it's a nightmare getting the binnacle apart, especially getting the needles off without breaking them....
Once it arrives I will, a full video was promised from where I bought it. Will let you know. |
Cheers mate, good luck with it... Pete
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
My god that cars a pain in the ass.
Your telling me!!! I'm working just to fix it!! |
