Home > Maintenance & Mods (L322) > Aarrgghhh |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Stick with it pall for now, Green ovals are never cheap to run when they go wrong you not sorted that coolant leak then? could be that O ring just below rad. If it dont work.......burn it!
29th Aug 2014 7:24pm |
Dave ray Member Since: 19 Sep 2011 Location: Wirral Posts: 92 |
Local indie couldn't trace the leak love the car it's my second but feel like pulling my hair out sometimes |
29th Aug 2014 7:35pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 468 |
I've had various coolant leaks on mine over the last couple of years. The first was a hose which had become displaced and had a groove cut into it by the bottom pulley. Solution; two inch gaffa tape. (After replacing the hose of course!).
30th Aug 2014 10:34am |
Presume you've also checked the coolant expansion tank bleed screw as the source of coolant loss Dave Ray?
30th Aug 2014 10:49am |
