If as you say it has snapped at the release lever end. The cable will be just inside the outer sheath. I had the same problem with mine a couple of months ago.
What I did was carefully cut away about 2 inches of the outer covering. Below this you will find wire wrapped around an inner plastic coating, this is what gives it it's rigidity and protection. I unwound the wire, again about 2 Inches and snipped it off. Then finally you will have another layer of plastic, carefully cut this away.
You should have exposed enough of the release cable wire now to be able to get a grip with pliers, mole grips and open the bonnet.
Hope that helps.
