![]() | Home > In Car Electronics (L322) > WD TV install for hard drive |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8005 ![]() ![]() ![]() |
You need to plug something else into the Aux in in the car & try the WD TV box on a TV in your house - basically narrow down whether the problem is with the car or the WD box |
Billydun34 Member Since: 04 Sep 2014 Location: Aberdeenshire Posts: 45 ![]() ![]() ![]() |
Thanks for the reply i have plugged my iphone into the aux in the car and i get the sound thru no problem, and also the wd tv works in the house no problem. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35674 ![]() ![]() |
have a look at how many 'bands' there are on the stem of the plug..most times a mono plug wont work in a stereo socket . ... - .- -.
Hi Stan forgive me but what stem am i looking for is it the jack plug? and what are the bands |
the plug that goes into the aux socket...compare that one with a plug that gives you sound ...
the plug has 3 black bands on it |
stcstc31 Member Since: 01 Jul 2014 Location: dublin Posts: 209 ![]() ![]() ![]() |
stereo plug should only have 2 black bands
^ what he said...try a plug with two bands.. ... - .- -.
the cable in question is the composite cable with the red yellow and white plugs on one end and a 3.5mm jack plug with three bands on the end of the plug that goes into the back of the wdtv box.
Yes - sounds like the right connections - red/white are audio.
Yes thats right Alistair |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Have you got some phono joiners and another stereo phono lead to stereo 3.5mm jack you can plug into the 3.5mm socket?
hi Joe i have another set of identical leads but no phono joiners, so you think you could get video and sound plugging it into the 3.5mm socket in the car? |
