Home > Technical (L322) > Diesel refueling issue
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
Sorry if this has been covered before. If it has, I can't find the thread.
MY03 TD6. When refueling, the fuel gun will not fit into the fuel pipe at all, in short the pipework on the fuel gun is larger than the fuel pipe on the car. I can get the diesel in no problem but I have to hold it tight up against the pipe.
Is this normal or am I missing something here?
Post #279627 7th Sep 2014 7:09pm
GrahamCharlton
England 2012 Range Rover Vogue TDV8 Stornoway Grey
I have the same issue with my 2011 TDV8. There's lots of talk on here about a yellow flap that prevents you filling the tank with petrol by mistake but in my case it simply seems like the filler neck is too narrow I've only had the car a couple of weeks so have only filled it once so will have a closer look the next time I fill up.
Post #279644 7th Sep 2014 9:06pm
JAYBOY
Graham
On yours you have the safety system that stops you putting petrol in.
If you go to the tools under the floor in the boot you will find a Yellow tool. Insert it into the filler and you will be able to fill properly. 2 minute job. Thumbs Up
Iphs
Im not sure they had this on your year.
If it did then follow above.
Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #279649 7th Sep 2014 9:40pm
Re: Diesel refueling issue
Turn the nozzle upside down and try Thumbs Up
Post #279664 7th Sep 2014 10:42pm
Stop using the commercial diseesel pump Whistle 2008 MY Supercharged
Post #279671 8th Sep 2014 2:16am
Question Unless your (yellow) fuel filler protection flap has activated a normal car diesel pump will of course fit into the filler pipe Question
Post #279678 8th Sep 2014 8:01am
iphs
Nope not in mine. I don't believe I have the wrong fuel device fitted. I can't see anything yellow down there. Just seems like the filler neck is to narrow Rolling Eyes
Post #279768 8th Sep 2014 8:01pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Like sex, you just have to give it wiggle & ram it in, if you're too gentle it just doesn't go in!!
Post #279778 8th Sep 2014 8:25pm
iphs
Laughing Thumbs Up nice one.
Just been having another look down the filler neck. The tube (if I may call it that) is flat on the top, like a closed U shape. is that how it should be ?
Post #279787 8th Sep 2014 8:39pm
JAYBOY
Thumbs Up Rolling with laughter Rolling with laughter 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #279790 8th Sep 2014 8:43pm
Mr Tee
I'll go have a look
Post #279792 8th Sep 2014 8:47pm
Mr Tee
Here you go:
Post #279799 8th Sep 2014 9:13pm
iphs
Yup, thats what I got. I will take your advice and give the gun a good shove next time.
Cheers.
Post #279803 8th Sep 2014 9:16pm
Mr Tee
I hold the pump at 90 degrees to get it in
Post #279807 8th Sep 2014 9:19pm
iphs
I will give it a little wriggle as well Laughing
Post #279808 8th Sep 2014 9:21pm
