Home > Off Topic - Other Cars > Weekend car
BrianC
Went to see the car and do like it. The alloys look to small for it. Has anyone down the 5 stud conversion to get better alloys to fit ? What's the diference between the 4.0 and 4.0 hc. Tvr figures are total lies of there power claims
Post #279432 6th Sep 2014 2:12pm
GrahamCharlton
England 2012 Range Rover Vogue TDV8 Stornoway Grey
I did the 5 stud conversion on mine and fitted the spider alloys. It totally transformed the cars looks. It took a lot of doing as the disks and callipers also had to be changed. The full strip down also meant it needed a full alignment setup afterwards as the caster and camber is fully adjustable on these cars. You also have to fit spacers in the steering rack to reduce the lock slightly to stop the larger wheels fouling on the arches. Well worth doing though.
Post #279647 7th Sep 2014 9:13pm
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I managed to find a set of Ford Diamond cut RS 17s which looked like a large version of the stock alloys, they transformed the way it looked... 4.2 Supercharged Vogue SE
Post #279651 7th Sep 2014 9:51pm
BrianC
Definetly getting, just trying to find the best one for decent money
Post #279665 7th Sep 2014 10:49pm
Pitsnow
I had a set of those on my Dax Rush:
http://www.imagewheels.co.uk/large_wheel_pages/b102.html
Imagewheels does 4 stud in all sorts.
Post #279712 8th Sep 2014 11:03am
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
I have got a N reg 400. Have always wanted one and finally got one this year. It was a decision between a 911 (996) or the Chim and i am glad i went with the TVR. Every time i go out in it i get questioned about it and the usual "give it a rev!".
The reliability seems no worse than any other performance car ( have done 3000 trouble free miles since may ) but then again i would say its in the same category as the landrovers-i.e not to be owned by people who are afraid to look under the bonnet every so often Thumbs Up
As said above, the chassis is the weak spot but i have found that pre 97 cars (grey/silver chassis) seem to survive better for some reason than the later cars (white chassis). Engines are good old rover V8s and if looked after are reliable
The difference between 400 and 400hc was a couple of engine tweaks and a few extra BHP but i don't find mine lacking Thumbs Up
I have fitted 16" wheels all round (was 15"f 16"r) after doing a big brake conversion. But i also have a set of 17"18" wheels that i use for trackdays Cool
Paul
 Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #279813 8th Sep 2014 9:40pm
BrianC
Car looks good Cool I still can't decide if I should scratch the tvr itch… I know it will be unreliable and cost lots to maintain but not many other cars will give you the same thrill
Post #280066 9th Sep 2014 8:48pm
marsie
It is the same with most cars of this type, get a good one and it will be the best money you have spent. Get a bad one and you will soon fall out with it!
Mine has been faultless (upto now) and the only bits i have fitted have been for my own reasons not because they failed. For example the full front brake upgrade from 260-324mm with brembos cost me less than £200. Upto now the only other spending i will be doing is down to cosmetics which you can expect on any 20+ year old car
Paul Paul
Post #280134 10th Sep 2014 9:41am
GrahamCharlton
Here are pictures of my Chimaera before and after the wheel conversion.
Post #280243 10th Sep 2014 8:15pm
BrianC
Looks good. How much roughly to do the conversion plus finding a good set of wheels and tyres
Post #280251 10th Sep 2014 8:54pm
GrahamCharlton
It's a few years since I did it but the figure of about £2000 comes to mind. The basic kit which included replacement hubs with 5 studs, discs which obviously also had to have 5 holes for the studs, new front callipers and the wheels and tyres all came from the TVR factory (that tells you how long ago it was!) the rest which was just really the rear callipers and carriers just came from a scrap yard. I spent a bit extra while I was doing it getting all the suspension re-bushed etc.
The interesting thing about this conversion kit is that it was supposedly created by TVR to get rid of a surplus of wheels and tyres they had. I'm not sure how true this is but I can believe if of TVR!
Post #280267 10th Sep 2014 10:04pm
