Home > Off Topic - Other Cars > Weekend car |
GrahamCharlton Member Since: 17 Aug 2014 Location: Newcastle upon Tyne Posts: 30 |
I did the 5 stud conversion on mine and fitted the spider alloys. It totally transformed the cars looks. It took a lot of doing as the disks and callipers also had to be changed. The full strip down also meant it needed a full alignment setup afterwards as the caster and camber is fully adjustable on these cars. You also have to fit spacers in the steering rack to reduce the lock slightly to stop the larger wheels fouling on the arches. Well worth doing though. |
7th Sep 2014 9:13pm |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 |
I managed to find a set of Ford Diamond cut RS 17s which looked like a large version of the stock alloys, they transformed the way it looked... 4.2 Supercharged Vogue SE |
7th Sep 2014 9:51pm |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 |
Definetly getting, just trying to find the best one for decent money |
7th Sep 2014 10:49pm |
Pitsnow Member Since: 17 Jul 2012 Location: Cleethorpes Posts: 183 |
I had a set of those on my Dax Rush:
8th Sep 2014 11:03am |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 915 |
I have got a N reg 400. Have always wanted one and finally got one this year. It was a decision between a 911 (996) or the Chim and i am glad i went with the TVR. Every time i go out in it i get questioned about it and the usual "give it a rev!".
8th Sep 2014 9:40pm |
Car looks good I still can't decide if I should scratch the tvr itch… I know it will be unreliable and cost lots to maintain but not many other cars will give you the same thrill |
9th Sep 2014 8:48pm |
It is the same with most cars of this type, get a good one and it will be the best money you have spent. Get a bad one and you will soon fall out with it!
10th Sep 2014 9:41am |
Here are pictures of my Chimaera before and after the wheel conversion.
10th Sep 2014 8:15pm |
Looks good. How much roughly to do the conversion plus finding a good set of wheels and tyres |
10th Sep 2014 8:54pm |
It's a few years since I did it but the figure of about £2000 comes to mind. The basic kit which included replacement hubs with 5 studs, discs which obviously also had to have 5 holes for the studs, new front callipers and the wheels and tyres all came from the TVR factory (that tells you how long ago it was!) the rest which was just really the rear callipers and carriers just came from a scrap yard. I spent a bit extra while I was doing it getting all the suspension re-bushed etc.
10th Sep 2014 10:04pm |
