![]() | Home > Maintenance & Mods (L322) > My rusty hole |
That would be Brighton ?, by the sea ! 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
ooiii!!!
Derby is well away from the sea |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
It won't be in a bit with all the global warming we are supposedly responsible for |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Is that why New York was 200ft under water 1000yrs ago then? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
Look under the sills, there are recesses with two piece trim clips, prise out the center piece, then remove the outer piece, the sill will now be free at the bottom, open both doors, sharply pull the sill away from the car starting at the back, it is on several push clips but they are tight, a sharp pull is better than a gradual one as you can bend the sill if you just pull it... It will pop off, then go to the front door and do the same, you then slide it out from under the rubber strip on the bottom of the plastic lower wing/fender piece, refit is reversal but several of the push fit clips will have broken so you may need to get some more from the dealer....
It is best practice to remove the front wing lower panels before you remove the side sill covers as there are clips that won't release with the panels in place sir |
