Home > Maintenance & Mods (L322) > My rusty hole
Page 3 of 3 <123
stan wrote:
luckily mine spent its time in brighton from new so i have minimal surface rust.
That would be Brighton ?, by the sea ! 2008 MY Supercharged
Post #280097 10th Sep 2014 1:41am
I thought that too, but stan's not too bright you know.... Laughing .
Post #280185 10th Sep 2014 3:31pm
ooiii!!!
it was somewhere inland from brighton cant remember the place so i just said 'brighton' , anyway well away from the salty sea you peasants... Twisted Evil .. ... - .- -.
Post #280193 10th Sep 2014 4:13pm
Derby is well away from the sea Twisted Evil .
Post #280219 10th Sep 2014 6:35pm
Laughing ... - .- -.
Post #280227 10th Sep 2014 7:07pm
mjdronfield
It won't be in a bit with all the global warming we are supposedly responsible for Laughing 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #280230 10th Sep 2014 7:24pm
Is that why New York was 200ft under water 1000yrs ago then? Whistle Whistle Whistle
Post #280285 10th Sep 2014 11:02pm
RR2008HSE
kingpleb wrote:
Granted Alu doesn't rust but it still reacts and goes nasty Sad like at defender doors and other alu bits Sad
Specially in areas where steel bolts bolt into the shell electrolytic corrosion will be a hell of a problem in 5-10years+
Absolutely. One plus with Al over Fe is aluminium oxide will stick and form a barrier. Flaky rust means that rusting accelerated. I think Al oxidation is more constant. I won't be happy with either, but I'm not sure how to get the panels off to see. Shocked
Post #280294 10th Sep 2014 11:32pm
Look under the sills, there are recesses with two piece trim clips, prise out the center piece, then remove the outer piece, the sill will now be free at the bottom, open both doors, sharply pull the sill away from the car starting at the back, it is on several push clips but they are tight, a sharp pull is better than a gradual one as you can bend the sill if you just pull it... It will pop off, then go to the front door and do the same, you then slide it out from under the rubber strip on the bottom of the plastic lower wing/fender piece, refit is reversal but several of the push fit clips will have broken so you may need to get some more from the dealer....
Get some cavity rust protection as there are loads of grommets where you can fill the sill up... Pete
Post #280328 11th Sep 2014 8:54am
It is best practice to remove the front wing lower panels before you remove the side sill covers as there are clips that won't release with the panels in place sir Bow down Bow down Bow down Thumbs Up
Post #280329 11th Sep 2014 8:58am
Page 3 of 3 <123
