Home > Technical (L322) > How much wiggle.
How much wiggle.
Just having a lie on the ground looking at the suspension....as you do.....
How much wiggle/twist should there be in the large front suspension arm (the one going diagonally toward the rear with the big bush on the end).
Can get a bit of twist into mine. Normal?
Cheers chaps. There is nothing that can't be fixed with a hammer😜😜
Post #280719 13th Sep 2014 12:40pm
Put a lever bar in behind the bush (between the bush & the subframe) and lever it (as if to squash the bush against its bolt) the arm should have 1-3mm of travel as you squash the rubber but should spring back into its original place. It will twist at the balljoint end "as thats what its designed to do" Thumbs Up Thumbs Up Thumbs Up
Post #280722 13th Sep 2014 12:46pm
Top man! I'll get my bar out. There is nothing that can't be fixed with a hammer😜😜
Post #280724 13th Sep 2014 12:52pm
Thumbs Up Bow down Thumbs Up
Post #280835 13th Sep 2014 10:56pm
