![]() | Home > Technical (L322) > Steering retract |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8801 ![]() ![]() ![]() |
Yes, three star drive screws under the steering column and drop the bottom bit off, then you will see a worm drive sticking towards you, luckily it has a slotted end, use a flat screwdriver and turn it till it's where you want it... Job done... you need a pretty long star drive to get the screws out... Pete
Dave ray Member Since: 19 Sep 2011 Location: Wirral Posts: 92 ![]() ![]() ![]() |
Thanks for that just till I get it looked at |
New column is very very expensive and AFAIK you can't buy the individual bits Pete
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
The parts can be sourced, I had an artical in one of my Land Rover mags about a german chap who makes either the bracket or gear at a good price. Im away at the moment not home for a week, pm me and I will look it up when I get back if you want |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
@Dave ray, mostly the white plastic bracket is broken, you can buy it at around 40GBP at your official LR Dealer, easy to fix, from the side of the dashboard you can look inside, and when you have fingers like a fog, you can fix from the side, otherwise from under the steering, it is a common problem. If the plastic nut is out of order, go to ebay.co.uk, and look at my offer / advice from STEERING Range Rover L322, best wishes, Uli (if questions, ask me in clear english)
@ Dear Joe90, watching the FullFatForum like a labrador-dog the meals on the kitchen table..... |
That's good to hear, must have a look at mine then that won't move anywhere...... Pete
