![]() | Home > Maintenance & Mods (L322) > SC leaking oil - Ladder Frame... Or something |
| RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 226
Worth checking that it is not running down from the cam cover gaskets. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Thanks RRBlue, will check.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
jeez, that looks alarming ryan....hope its not to much of a sort out.. ... - .- -.
Would just like to know what the components covered in oil and as pictured are Stan.
| 87RJD Member Since: 01 Dec 2013 Location: Wokingham Posts: 103
Looks like the front diff casing to me, you can see the prop shaft connected to it SC 4.2, 2012 face lifted, 25K miles, 1 previous owner
Thank you, it does look new and the front diff was replaced recently.
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1891
Have seen the sump/crankcase leak on the 4.2 before.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8791
Would be strange if the seals had gone already. Take it back get them to sort it. There is nothing that can't be fixed with a hammer๐๐
Reduced engine power in April resulted in the SC water pump and crankcase breather being replaced.
Reported to dealer today and booked in for 1 week on Tuesday as earliest date they had a courtesy car
Car in at garage today. Call late afternoon reporting that they wiped down the saturated components and sourced the leak to a bolt that hadn't been fully tightened on the Front Diff during recent works.
Nice result, mine is in tomorrow, to see if they can finally sort out the transfer box leak!
Good luck NMJ!
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
Well you can't do more than that to help them hope it all works out and the leak is gone when you get it back |
| All times are GMT |
