Home > Maintenance & Mods (L322) > SC leaking oil - Ladder Frame... Or something
Page 1 of 4 1234>
pld118
From the outset, it would be nice to have confirmation as to what the aluminium?/ silver box with the X pattern (pictured) is officially called please?
Anyway, whilst underneath the car today I noticed wet patches on one of the bolted on plastic under trays underneath the engine bay.
I removed the under tray and this is what the oil catching side looked like (like it's been hiding a leak for a while is what it looked like!). The plastic lugs of the tray face towards the back of the car and the straighter edged part points towards the front of the car when fitted:
I then got right underneath the car and managed to take these pictures which show fresh oil deposited on or leaking from the components in question. I don't know the names of the components.
Can anyone please enlighten me as to the component parts and what might be going on please?
Thanks
Post #281721 18th Sep 2014 2:02pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Worth checking that it is not running down from the cam cover gaskets. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #281738 18th Sep 2014 5:01pm
pld118
Thanks RRBlue, will check.
My first thought went towards the following leaks that were supposedly dealt with in the past 12 months:
• Oil Leak - Engine - visible via discharge out of under tray holes. Replaced the front offside driveshaft seal. Later discovered was also a minor oil leak via an oil breather hose which was also replaced.
• Oil Leak - Front diff - diff was weeping/ had a teardrop type leak. Replaced the full front diff and the pinion seal.
Post #281740 18th Sep 2014 5:47pm
jeez, that looks alarming ryan....hope its not to much of a sort out.. ... - .- -.
Post #281741 18th Sep 2014 6:07pm
pld118
Would just like to know what the components covered in oil and as pictured are Stan.
That would be a good starting point.
Post #281766 18th Sep 2014 8:46pm
87RJD
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Looks like the front diff casing to me, you can see the prop shaft connected to it SC 4.2, 2012 face lifted, 25K miles, 1 previous owner
Triumph TR6 1973
Triumph Bonneville 1970
Previous:
2002 TD6
Merc SL500
Escort RS Cosworth
RR 3.9 Vogue
4.2 E type Jag replica (challenger)
Escort RS2000 (many)
Escort RS 1600 Turbo
Post #281767 18th Sep 2014 8:50pm
pld118
Thank you, it does look new and the front diff was replaced recently.
Interesting!
Post #281784 18th Sep 2014 9:30pm
Mikey
Have seen the sump/crankcase leak on the 4.2 before.
Most of the time, it tends to need the bolts tightened up a little. Whether they are not tight enough from.the factory, or they work loose over time, who knows. But it's free to try, and has cured quite a few oil leaks for me Thumbs Up
Post #281785 18th Sep 2014 9:35pm
Would be strange if the seals had gone already. Take it back get them to sort it. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #281786 18th Sep 2014 9:35pm
pld118
Reduced engine power in April resulted in the SC water pump and crankcase breather being replaced.
Surely linked to that work and/ or the other work that I've listed as having been done.
What a pain!
Post #281791 18th Sep 2014 10:06pm
pld118
Reported to dealer today and booked in for 1 week on Tuesday as earliest date they had a courtesy car
Post #281943 19th Sep 2014 8:29pm
pld118
Car in at garage today. Call late afternoon reporting that they wiped down the saturated components and sourced the leak to a bolt that hadn't been fully tightened on the Front Diff during recent works.
No harm done, all sorted and car ready for collection first thing tomorrow.
Knew deep down that it was going to be connected to recent repairs but always some uncertain moments when a diagnosis is awaited and you wonder if you're going to get that sinking feeling when updated Thud
Mrs pld doesn't even know the car is away... Managed to tuck the courtesy car up in our garage without her noticing. Not worth the hassle! Laughing
Post #283806 30th Sep 2014 9:04pm
Nice result, mine is in tomorrow, to see if they can finally sort out the transfer box leak!
I've even bought the part I reckon is leaking for them, just to make sure that they change the right thing! There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #283819 30th Sep 2014 10:30pm
pld118
Good luck NMJ!
Post #283820 30th Sep 2014 10:32pm
Sandyt
Well you can't do more than that to help them hope it all works out and the leak is gone when you get it back Thumbs Up
Post #283840 1st Oct 2014 7:39am
Page 1 of 4 1234>
