![]() | Home > Maintenance & Mods (L322) > Service Intervals - Help Needed! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
Services should be carried out every 12 months as it states in your service book... The only reason you have a service interval meter is for when you cover high milage (i.e. do more that the 16/18k a year)
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3807 ![]() ![]() |
Blimey, 3 years and 24k between services - what if your gearbox or diffs needed topping up? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
mmiata Member Since: 12 Jul 2013 Location: Budapest Posts: 104 ![]() ![]() ![]() |
CamRR Member Since: 21 Sep 2014 Location: Cambridge Posts: 3 ![]() ![]() ![]() |
Thanks everyone who's replied so far. The service schedule someone's kindly posted is for model year 11 onwards, so doesn't apply to my car (which is 07 model year). Also, there's no mention of annual servicing in my service book, otherwise my car wouldn't have been serviced properly since it was new, and that's unlikely as it's been maintained by a main dealer.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Never seen the service indicator and have done 20k in 10 months but do have it serviced every year |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
This is my manual...2007 (08MY) 3.6 TDV8
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
CamRR,
It is likely your service indicator has been disabled as per the armoured spec RR's - it should come on as a minimum every 12 months or less if you drive hard or high miles 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
http://british4x4outfitters.com/Assets/PDF...verJAG.pdf
I haven't ever noticed it coming up when I turn the key, and I only turn it one notch until the glow plugs light goes out so I think I'd notice if a message came up. Sounds like it might be faulty or have been disabled. Can't imagine why though! |
