![]() | Home > Technical (L322) > Hi and "Help my brakes are not working"!! |
jfarrell32 Member Since: 23 Sep 2014 Location: Straffan Posts: 25 ![]() ![]() |
Hi, I have just joined the forum on the recommendation from a friend. I was on Landyzone for the past few years but this site was recommended as being more focused on the RR.
Time to do some research here but I have vague memories of the ABS unit needs to be purged by a diagnostic tool specific to a Range Rover , head for the search button and have a rummage.
Why the hell was he test driving it? ![]() |
Same reason he didn't bleed the air from the ABS block I guess , didn't know any better |
Thanks for suggestion. |
Hi John im only a stone throw from you in Celbridge .What garage do you have it with as may be able to suggest alternative if issue cant be sorted. |
stcstc31 Member Since: 01 Jul 2014 Location: dublin Posts: 209 ![]() ![]() ![]() |
i am in monkstown
It is RADS in clane. He has all the technology and does the service etc. for me, checked with him earlier and he confirmed he had bled block and was going to drain and start again! Will let u know! Strange!!! |
Thanks, will do |
am now told by the garage that it may be the master cylinder because he cannot find any air in the system. Says the seals may have been damaged when the system was empty and I was driving it (only for a few kms to garage after discovering problem). Does this sound likely? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Have a read of this
Thanks - will have a read. rgds john |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
You drove it with a "split brake hose" ![]() ![]() Do you guys not have recovery vehicles over there? I wouldn't even start the engine on a FF with a split brake hose... Let alone try driving it sir ![]() |
Great help thanks - I'll stick that in the "I told you so" bucket. |
