Home > Technical (L322) > Hi and "Help my brakes are not working"!!
jfarrell32
Ireland
Hi, I have just joined the forum on the recommendation from a friend. I was on Landyzone for the past few years but this site was recommended as being more focused on the RR.
My 2007 TD8 is currently in the garage. I have a split brake line at the front right wheel. I thought this would be an easy fix but the mechanic called me earlier today and said he cannot get the pedal to go back to normal position no matter how much he has bled and checked the system. Each test drive the pedal goes to the floor. He claims he used pressure to fill the system and had checked everything but still is not getting the pedal to its normal position. So now what was supposed to be a simple fix is now a mystery - does anyone have any suggestions or advice. Thanks in advance and I promise I will add back some advice to the site in the coming months (i have had a Disco previously so have lots of LR experience). Rgds John
Post #282788 25th Sep 2014 3:11pm
Time to do some research here but I have vague memories of the ABS unit needs to be purged by a diagnostic tool specific to a Range Rover , head for the search button and have a rummage.
Bingo
http://www.fullfatrr.com/forum/topic20532....=purge+abs 2008 MY Supercharged
Post #282790 25th Sep 2014 3:19pm
Re: Hi and "Help my brakes are not working"!!
Why the hell was he test driving it? Shocked
Post #282796 25th Sep 2014 3:47pm
Same reason he didn't bleed the air from the ABS block I guess , didn't know any better Shocked 2008 MY Supercharged
Post #282800 25th Sep 2014 4:02pm
jfarrell32
Ireland
Bingo
Thanks for suggestion.
Post #282812 25th Sep 2014 4:43pm
Googsy
Hi John im only a stone throw from you in Celbridge .What garage do you have it with as may be able to suggest alternative if issue cant be sorted. Thumbs Up Conor. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #282818 25th Sep 2014 5:31pm
stcstc31
Ireland 2005 Range Rover SE Td6 Atacama Sand
i am in monkstown
if can help let me know
Post #282819 25th Sep 2014 5:33pm
jfarrell32
Ireland
It is RADS in clane. He has all the technology and does the service etc. for me, checked with him earlier and he confirmed he had bled block and was going to drain and start again! Will let u know! Strange!!!
Post #282832 25th Sep 2014 7:00pm
jfarrell32
Ireland
stcstc31 wrote:
i am in monkstown
Thanks, will do
Post #282833 25th Sep 2014 7:01pm
jfarrell32
Ireland
am now told by the garage that it may be the master cylinder because he cannot find any air in the system. Says the seals may have been damaged when the system was empty and I was driving it (only for a few kms to garage after discovering problem). Does this sound likely?
Post #282937 26th Sep 2014 11:24am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Hmm sounds odd, the master cylinder seals would usually be damaged through over pressure- not sure how you can over pressurise something with nothing to compress?
I've heard of master cylinder seals being done for with over-zealous brake pedal mashing to bleed the old fashioned way.
I'm sure someone who knows more will give a better steer.
Post #282942 26th Sep 2014 11:43am
Have a read of this
http://forums.bimmerforums.com/forum/showt...ad-(brake)
Not doubting your guy, but it seems odd that your MC just blew, more likely to get worse over time, unless a seal completely disintegrated.
Read up on the various tests that need to be done, it is weird that the brake pedal will go to the floor when everything is OK, just the way the servo works. .
Post #282965 26th Sep 2014 4:26pm
jfarrell32
Ireland
Thanks - will have a read. rgds john
Post #283017 26th Sep 2014 11:17pm
You drove it with a "split brake hose" Shocked really Exclamation
Do you guys not have recovery vehicles over there? I wouldn't even start the engine on a FF with a split brake hose... Let alone try driving it sir Shocked
Post #283020 26th Sep 2014 11:26pm
jfarrell32
Ireland
Great help thanks - I'll stick that in the "I told you so" bucket.
Post #283032 27th Sep 2014 5:01am
