Home > Technical (L322) > Britpart drilled/slotted disc's DA4609 have you got? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Hi all, I've just fitted some drilled and slotted disc's from Britpart, and I'm having some BIG PROBLEMS
27th Sep 2014 8:09pm |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 |
I have them on mine but there is no significant vibration. Slight drone under moderate braking bu tunder hard braking the are good. Sounds like something else is out.
27th Sep 2014 8:26pm |
I know!!!!!!!!!!
27th Sep 2014 8:29pm |
Yes I did use new pads, and they are ecb, I've changed hundreds of discs in my time and never have I had this. I was just wondering if it was a drilled slotted thing. |
27th Sep 2014 8:33pm |
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 |
Never had any problems in the past with that type of disc, although I have never used Britpart. |
27th Sep 2014 8:39pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
Its a Britpart thing
27th Sep 2014 8:43pm |
OK so I do have a set of wobbley discs
27th Sep 2014 8:50pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Thats why they are known as S H 1 T P A R T |
27th Sep 2014 9:30pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2221 |
As Craig says absolute |
27th Sep 2014 9:50pm |
So what should I replace them with?? and dont say std. they wont take the punishment that I'll give them!! |
27th Sep 2014 10:02pm |
Brembos....... There is nothing that can't be fixed with a hammer😜😜
27th Sep 2014 10:04pm |
I fitted Terrafirma drilled and grooved discs to my D3 (with Brembo calipers)
27th Sep 2014 10:12pm |
At least you got a few months use out of them, mine warped getting it off the drive |
27th Sep 2014 10:30pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
i have drilled discs on front of mine fitted under previous owner. they run true and unnoticeable, except a very mild pedal vibration when motorway scare-dy-braking.
28th Sep 2014 11:19am |
