Home > My Range Rover > Project Fatty off roader....PICTURES NOW BACK
Page 9 of 31 <123 ... 8910 ... 293031>
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Thanks - if Parkamoor is what I'm thinking of, must have been very tight between the walls.
Post #280899 14th Sep 2014 1:44pm
RR2008HSE
Thumbs Up Well done. It's nice to see an RR in its element.
Post #280990 14th Sep 2014 8:56pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
What size Coopers?
Post #281014 14th Sep 2014 9:34pm
Trommel, yes it was pretty tight....
RR2008HSE, it sure is amasing off road.... it was only us and the Jeep with 37's and front and rear ARB lockers that did everything first time...
Emperor Mong, 255/55/19's Pete
Post #281020 14th Sep 2014 9:48pm
Great stuff! Thumbs Up Si. <This is my name.
Post #281062 15th Sep 2014 9:22am
Just driven to my mums in Bucks, Rangie was a bit hot when I got here
This is what's left of the fuse for the fans??!!?!?!??!
The fuse is still ok, only thing I can think is that it got muddy water in it from a pay and play at KORC and made the connections dirty which set up a high resistance in the fittings.....
Brother coming tomorrow with tools to fit an inline 80amp maxi fuse..... Pete
Post #283206 27th Sep 2014 9:39pm
JAYBOY
You were lucky there Pete.
Normally a loose connection would be the cause of that.
I'm not keen on screwed connections on a car they just come loose with the vibration.
Good luck with the fix. Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #283216 27th Sep 2014 9:55pm
Yep, luckily melted the plastic first and insulated it....
Going to solder in then heat shrink the replacement... Pete
Post #283237 27th Sep 2014 11:11pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Pete your where lucky, maxi fuses are far superior, I have them on my challenge 90. Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #283261 28th Sep 2014 9:05am
mjdronfield
Piggin 'ell. You would have had to test your snorkel really quickly if that had sparked up !
So long as you have caught it and can upgrade the wiring.
Trust thats the only place you have those connections open to the mud ?
Onwards and upwards as they say.......
PS - VIN visible in above pic if that type of thing bothers you..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #283268 28th Sep 2014 9:38am
Yeah.. It looked a good bit of kit but obviously not up to the job...
All other joints are fine and soldered...
Mark, if someone wants to clone mine I'll take it as a compliment!!!!!!! Pete
Post #283284 28th Sep 2014 10:14am
After much thought I have decided to go to 18 x 7 1/2" rims and a taller tyre to give some extra sidewall for off roading...
The 19 x 8's with 255/55/19 tyres have a sidewall height of just over 5 inches, this makes the sidewalls vulnerable to damage from pinching when crossing loose rocks, the 8" rims mean the wheels are too exposed and get damaged easily as well...
I decided to go for a 275/65/18 size tyre, these stand nearly 3" taller than stock with a height of over 32" with a 7" sidewall and makes them about 7% taller than stock so should just about make the speedo spot on accurate...
They will also protect the wheels far more as they are 20mm wider on a thinner rim width...
They should fit the FF with only minor mods.....
I ummed and arred for some time over All terrain or full muds so started reading all the reviews on tirerack, there are 1000's of reviews from users so very useful, a bit like Tripadvisor for tyres..... I decided on some aggressive all terrains that apparently work better than a lot of full muds in the sticky stuff...
I've finally decided on the General Grabber AT2, these have stunning reviews from 1000's of people and seem to be rated far above the industry renowned BF Goodrich AT.
So four of these have been ordered from our site sponsor AJS4X4, who were far cheaper than anyone else. Thumbs Up
A very nice, near immaculate set of these was bought from our very own nicedayforit Thumbs Up
A new set of early nuts have been ordered from Dan.... Thumbs Up
More pics when they are fitted next week..... Pete
Post #287437 18th Oct 2014 9:57pm
Harris
United Kingdom 2006 Range Rover Vogue TDV8 Zermatt Silver
AT2's are very good had them on my old P38 the missus has the newer AT's on her disco and I don't think they are quite as aggressive
Post #287438 18th Oct 2014 10:08pm
Seems they brought out the AT as the AT2 is so close to a mud tyre.... Pete
Post #287441 18th Oct 2014 10:13pm
Have the at's on one of the hilux and they are wearing well and are definitely slightly less agressive than the at2 you have ordered. Still a bit of overkill for what we need! But it came with them on, the standard tyres are Bridgestone dueller which are pretty much standard road tyres. There is nothing that can't be fixed with a hammer😜😜
Post #287446 18th Oct 2014 10:20pm
