Home > Technical (L322) > Jumping out of gear
Prepros123
England 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Jumping out of gear
Hi I am a Newbie here but have had Range Rovers on and off for 30 years.I have had my current 2002 Model for 7 years and regularly commute from Surrey to Cornwall hence rocketship mileage. Over the last six months it has developed a bad habit. If slowing down down for example coming to a roundabout then accelerating to go it will jump out of gear. You then have to pause on accelerator and then slowly accelerate like an old man.Sometimes it will do this around town and go into Trans Failsafe mode. Any suggestions please Question
Post #283260 28th Sep 2014 8:55am
ebajema
First trick is to clean the gearbox linkage underneath the car with WD40 and then covering it in grease. That seems to resolve a lot of these type of issues. MY 2010 5.0 SC Galway green and sand interior!!
Post #283265 28th Sep 2014 9:17am
Mikey
Wrong gearbox Embarassed
Post #283288 28th Sep 2014 10:42am
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Mine did exactly the same, a few squirts of WD40 on the linkage underneath and it was sorted in seconds.
Very obvious where to squirt if you have someone change gear whilst you are underneath.... 4.2 Supercharged Vogue SE
Post #283321 28th Sep 2014 2:33pm
Not recommended "have someone change gear while you are underneath" Shocked Shocked
Use a mirror or camera Thumbs Up
Here is link to wiki article, including photos. Much the same for petrol and diesel.
http://www.fullfatrr.com/forum/post87201.html#87201 .
Post #283361 28th Sep 2014 5:40pm
Prepros123
Hi
Many thanks all for the advice and link. Have found the cable as shown so will give it a good squirt at weekend
Post #283614 29th Sep 2014 6:41pm
Chauch
You do not have the have the engine running, I would hope common sense would prevail! 4.2 Supercharged Vogue SE
Post #283642 29th Sep 2014 7:27pm
