Home > Technical (L322) > Slow to pull off if left a cpl weeks
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
Hi
If on occasion I haven't driven the FF for say a week and a half, (I leave it in P with the parkbrake off in not using for a bit, cause my disco epb used to stick so got paranoid) when you first get in to pull off, the engine revs and initially it pulls away very slowly, after a couple of seconds it picks up and it drives fine.
No lack of acceleration, no lack of throatle response, no gear changing issues. Is that normal? Could it just be resistance from brakes for being parked up so long? Although you don't get the cracking sound of slightly corroded breaks coming free. 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #283493 29th Sep 2014 9:49am
miggit
Hi, it might be the oil in your gearbox is draining into the sump during its long sit, it is just taking a short time to fill the system. I have noticed that if I try and pull away in a hurry from a cold start there is a delay before drive engages. But if I put it in gear and wait a few seconds all is good! maybe you need to slow down on the get away, I do Very Happy
I've found that selecting drive and then prodding the sat nav, or something of a similar delay produces instant throttle responce... 2 seconds can seam like an eternity when your rushing! Yesterday I couldn't spell Engineer... Today I are one!
Post #283509 29th Sep 2014 10:58am
MachineHead
Thanks for the answer, that kinda makes sense, it certainly doesn't have any issues driving Thumbs Up
Yeah I should maybe consider leaving on time and not rushing, I usually do jump in fire up and go. I shall give it a try Thumbs Up 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #283608 29th Sep 2014 6:20pm
miggit
Thought that you were suppost tobe more laid back in France, with a slower pace of life, wot went wrong?? Yesterday I couldn't spell Engineer... Today I are one!
Post #283621 29th Sep 2014 7:04pm
Sandyt
Might be lack of fluid my p38 used to do this but only if slightly low on oil might be worth a check
Post #283629 29th Sep 2014 7:10pm
MachineHead
oops I'm back in Scotland, I change the flag when go over to the holiday house, which I am still doing a lot of renovation to.
I shall immediately rectify my flag Laughing Thumbs Up 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #283632 29th Sep 2014 7:18pm
MachineHead
Cheers sandy i'll have a look, never hurts to be cautious Thumbs Up 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #283635 29th Sep 2014 7:19pm
Could be the old sticky gearbox cable, taking a few secs to get into the drive position.......
Search on that and lube it up with a liberal application of grease/wd40. And all should be fine. There is nothing that can't be fixed with a hammer😜😜
Post #283636 29th Sep 2014 7:19pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
A full fat as get away car....don't turn it off while you're waiting in front of the bank Cool
Post #283637 29th Sep 2014 7:21pm
MachineHead
Thanks Thumbs Up I'll add it to the list of things to check, gives me something to do Laughing 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #283638 29th Sep 2014 7:21pm
MachineHead
Rolling with laughter I'd need the bank job to pay for the repairs so it would be a never ending circle.
Although not to temp fate ... no I'm not saying it Laughing 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #283639 29th Sep 2014 7:24pm
I would doubt it is low in fluid, unless you can see an obvious leak there is nowhere for the fluid to go. Be careful when checking the level it needs to be at the correct temperature to give the right level, if checked when cold it will appear low! There is nothing that can't be fixed with a hammer😜😜
Post #283645 29th Sep 2014 7:31pm
MachineHead
There are definitely no leaks and it was serviced 5 months ago, full inspection service, pretty sure all fluid and oil checks were on the invoice too now that you mention it. 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #283647 29th Sep 2014 7:33pm
Try lubing the cable. Can't hurt. There is nothing that can't be fixed with a hammer😜😜
Post #283650 29th Sep 2014 7:35pm
MachineHead
Cheers i'll have a peek tomorrow, I might even look at my towbar ... then decide to leave it in the boiler room again Laughing 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #283651 29th Sep 2014 7:36pm
