Home > Technical (L322) > Rear View camera and tyre/body predicted lines
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
on my 10MY tdv8 the yellow lines for the tyres and dashed lines for the body work are overlaid on the rear view camera screen when rev is selected, but they dont move when the steering wheel is turned. i believe they should. what should they do and is this a known fault/easy fix?
as an aside the front axle graphics work in 4x4info showing wheel direction as steering wheel is turned.
Post #283184 27th Sep 2014 9:19pm
never heard of these lines moving, are you sure?.....whats it say in the manual? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #283186 27th Sep 2014 9:22pm
ebajema
I can't remember them moving on mine but I seem to remember they did on the Disco4 I rented some time ago (2012 model I think). So maybe the 2010 they didn't have the moving lines yet and it came in on later models. I wonder if a software upgrade would be available by now that allows the moving lines. Maybe check with a dealer or someone on here with a Faultmate that has done the update to the latest ECU software on all ECUs. MY 2010 5.0 SC Galway green and sand interior!!
Post #283248 28th Sep 2014 4:16am
JST
its not in the manual, just says predicted lines.
it may be that i am just used to the later models at work that all have moving predicted lines, maybe as above it wasnt a feature on 10MYs, dont know. Cheers
James
Post #283500 29th Sep 2014 10:24am
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Moving lines were only available as part of the Vision Assist Pack which included the other cameras.
Post #283687 29th Sep 2014 8:52pm
mzplcg
^ Which means you must be able to turn it on in the CCF then. If it was an option on any model it can be retro-fitted and enabled. Would probably need an IID tool though as I doubt a dealer could enable it.
Post #283694 29th Sep 2014 9:24pm
JST
cheers Cheers
James
Post #283695 29th Sep 2014 9:26pm
Its also a different camera on the vision assist so NO it won't be a CCF turn on off job I'm afraid Rolling Eyes
Post #283696 29th Sep 2014 9:29pm
Autobiography
Yes, the camera is a much better quality.
Surely you can just purchase the better camera and get the lines without even enabling anything?
Post #283700 29th Sep 2014 10:03pm
Different plug (more wires on the vision assist cam) so not so sure you can...
Post #283703 29th Sep 2014 10:06pm
