![]() | Home > Technical (L322) > Rear View camera and tyre/body predicted lines |
never heard of these lines moving, are you sure?.....whats it say in the manual? ... - .- -.
I can't remember them moving on mine but I seem to remember they did on the Disco4 I rented some time ago (2012 model I think). So maybe the 2010 they didn't have the moving lines yet and it came in on later models. I wonder if a software upgrade would be available by now that allows the moving lines. Maybe check with a dealer or someone on here with a Faultmate that has done the update to the latest ECU software on all ECUs. MY 2010 5.0 SC Galway green and sand interior!!
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
its not in the manual, just says predicted lines.
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
Moving lines were only available as part of the Vision Assist Pack which included the other cameras. |
^ Which means you must be able to turn it on in the CCF then. If it was an option on any model it can be retro-fitted and enabled. Would probably need an IID tool though as I doubt a dealer could enable it. |
cheers Cheers James |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Its also a different camera on the vision assist so NO it won't be a CCF turn on off job I'm afraid |
Yes, the camera is a much better quality.
Different plug (more wires on the vision assist cam) so not so sure you can... |
