![]() | Home > In Car Electronics (L322) > Heated door mirrors ? |
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 ![]() ![]() ![]() |
Perhaps just remove the glass, be brave with a wide leaver
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 ![]() ![]() ![]() |
Does the glass just pop out ? |
Yes it does, again rave gives you some tips
mike37 Member Since: 17 Nov 2013 Location: East Mids Posts: 36 ![]() ![]() |
I thought they only came on with the front demist program? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7955 ![]() ![]() ![]() |
I thought they only came on below a certain temp.
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Just checked my handbook - says they come on automatically when a certain temp is reached (no idea what temp though) !!
Ok just found a fault on the IDD tool saying...AO driver door mirror heater: open circuit
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35761 ![]() ![]() |
open circuit means a break in the supply of power , maybe the wires are chaffed or broken? ... - .- -.
Ok Stan thanks, will investigate further!!! |
Take the glass out and test by supplying 12v if they warm then the glass is fine and the real fun begins. The two cables run in through the door behind the door card to their own connector IIRC. From there they go into the door loom and then into a whole army of cables |
Ok checked the glass on the mirrors.. One heated |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
So, if we are above a certain temperature, they will not work?
