![]() | Home > Technical (L322) > Heater/climate settings when you first start car |
nobbyclark Member Since: 16 Sep 2014 Location: Cumbria Posts: 131 ![]() ![]() |
Ok, so I've had the car since last Friday and am really enjoying it. But one thing is irritating and I haven't worked out how to change it: when I switch on the car, the heater/climate settings default to A/C on, AUTO on and the blower on about medium. I want it to be whatever I left it at the last time I switched off, which is A/C off, AUTO off and blower on 2nd position directed at the windscreen. Is this possible? |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
IIRC, its a feature |
What car have you got nobby, please complete your profile |
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 ![]() ![]() ![]() |
Why auto off ? |
Quote from handbook:
I do question the word "desired" in the above, I guess this is based upon the temperature settings made that Auto mode works to. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Mine's an 2008. If I press the fan button, then it goes off auto. It doesn't reset to auto on restarting the car. If was on manual, it will stay manual. Some temperature changes will reset it to auto.
Mine's a 2010, will update profile soon.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
i'm sure the owners manual explains the procedures ...
milesg Member Since: 18 Dec 2013 Location: Gloucestershire Posts: 120 ![]() ![]() ![]() |
Nobby my 2010 does the same. A tad annoying. Now sold - MY2010 Range Rover Vogue SE - Santorini Black & Ivory Leather |
I believe the logic behind this is that if a car has been parked up it starts kicking air out at an ok speed so as to get the cabin aired as it were. This helps clear windows and such like without much faff and the way i deal with it is as above, setting to manual |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Is it not an additional memory feature of the keys, i.e. automatic reset on the memory seat, steering column, mirrors, etc., dependent on which key is used to open/unlock the FF.
thats a thought , set the heating as you like it and then press the seat memory button.. ... - .- -.
It could be an MY06 function for the heating though as the changeover to the newer integrated systems occurred then. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Will try that. I did have some success with it remembering the settings at one point last Friday. But every time I've used the car since, it goes into Auto mode by default. |
