![]() | Home > Technical (L322) > Td6 Still Won;t start |
Fuel pump near the rear wheel would be the first item to check |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7930 ![]() ![]() ![]() |
Thats what I'd have thought initially, but he says pumps have been replaced, so I assume it was both of them.
Fuel pump relay? |
The rail sensor could indeed be at fault.
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
Hey guys thanks for the reply. The fuel pump relay is ok, because there is plenty of fuel at the filter and the injectors.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6423 ![]() ![]() |
I've seen on here somewhere the need to replace the fuel rail wiring loom (complete) or the fuel regulator as this can cause similar problems?
But if easy start gets her going and she works fine after that, I would check the glow plugs and wiring first. Or have you tried and tested all that already ?? MY 2010 5.0 SC Galway green and sand interior!!
Will have a read of that link now...
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1836 ![]() ![]() |
You need to do an injector leak back test, while still on the car. This will highlight any internal leaks in the injector, which is a well known issue with the TD4/TD6 |
Very true you don't need the glow plugs unless it gets to -10 or lower they then help with cold starting quite a bit!
Cheers Lads. I might give that a try.
I'll have a look in a bit and compare for you |
Cheers Kingpleb. When I say turning over; I mean attempt to start.
When I had issues I was getting a low pressure reading of 389.3 low pressure and 16376 high pressure.
