![]() | Home > Technical (L322) > Td6 Still Won;t start |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Fuel pump near the rear wheel would be the first item to check |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
Thats what I'd have thought initially, but he says pumps have been replaced, so I assume it was both of them.
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
Fuel pump relay? |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
The rail sensor could indeed be at fault.
| theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305
Hey guys thanks for the reply. The fuel pump relay is ok, because there is plenty of fuel at the filter and the injectors.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6433
I've seen on here somewhere the need to replace the fuel rail wiring loom (complete) or the fuel regulator as this can cause similar problems?
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
But if easy start gets her going and she works fine after that, I would check the glow plugs and wiring first. Or have you tried and tested all that already ?? MY 2010 5.0 SC Galway green and sand interior!!
Will have a read of that link now...
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1883
You need to do an injector leak back test, while still on the car. This will highlight any internal leaks in the injector, which is a well known issue with the TD4/TD6 |
Very true you don't need the glow plugs unless it gets to -10 or lower they then help with cold starting quite a bit!
Cheers Lads. I might give that a try.
I'll have a look in a bit and compare for you |
Cheers Kingpleb. When I say turning over; I mean attempt to start.
When I had issues I was getting a low pressure reading of 389.3 low pressure and 16376 high pressure.
