![]() | Home > Technical (L322) > L322 SUSPENSION KNIGHTMARE... |
I presume your not getting any other codes up then? Even after changing the pressure switch? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8804 ![]() ![]() ![]() |
Does it lose height overnight?? Pete
D8DEL Member Since: 14 Nov 2013 Location: AIRDRIE, North Lanarkshire Posts: 26 ![]() ![]() ![]() |
C1A20 is the fault code. Slow building pressure to resorvoir is the explanation. Can't understand it myself, especially with everything I've just done. I don't seem to have any leaks either as the black pipe that feeds th air tank blows like mad when disconnected from the compressor. It doesnt loose height overnight either and when I start her and change the height setting, she says "VEHICLE LIFTING SLOWLY". The only bit I didn't change was the black block that is connected to the compressor with rubber push mounts and has the black n 2 blue pipes coming off it. She's a 2006 model, is this a part thats prone to failing?. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3950 ![]() ![]() ![]() |
When I had trouble with my compressor it was because I had been messing with the IDTool and left it set in tight tolerance mode which caused no end of problems, some of which were like the ones you describe. Geoff |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
I had exactly the same problem on mine - the blue pipe that comes out the spare wheel well and up to the valve block was at fault.
