Home > Maintenance & Mods (L322) > Acceleration died - Throttle actuator shutdown |
Ryan its Probably a "feature".......
11th Oct 2014 10:53pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
Did you catch the brake pedal at the same time as the throttle pedal?
11th Oct 2014 10:58pm |
According to the bible that is rave, the throttle position is recalibrate each each ignition cycle.
11th Oct 2014 11:13pm |
Thanks chaps, particularly NMJ... I did indeed stamp on the brakes.
11th Oct 2014 11:31pm |
Wonder if it thought it was about to be in a crash and cut the fuel...... Possibly a system somewhere for that? There is nothing that can't be fixed with a hammer😜😜
12th Oct 2014 9:13am |
This happened again last night. Same as before, when I was braking, accelerating and braking in quick succession to try and stop the onset of front driver's side wheel squeal. Disconcerting when it happens but it does seem like a vehicle defence mechanism of sorts. Cleared the fault in seconds with the IID tool. |
21st Oct 2014 6:26am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
You maybe giving her travel/motion sickness to which she objects and requests a break sir |
21st Oct 2014 10:40am |
Seems like the an ELBSAP type error....... Drive on.
21st Oct 2014 6:43pm |
Don't get me wrong, I didn't fear much wrong with the car to make it shut down other than the give her a break conclusion... Or new pair of brakes [pads]
21st Oct 2014 6:47pm |
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 |
This is why we've gotten into this field in the first place, I wouldn't leave without one myself! |
22nd Oct 2014 5:26pm |
Couldn't agree more Pat. Can't believe I didn't get an IID tool sooner. Also a worthy reminder to carry it in the car which unless having read Cam Tech Craig's previous post about doing just that, I would have stored mine in my garage.
22nd Oct 2014 5:34pm |
Spot on, the regular IIDTool still has its place even with the BT offering. It does feel at home in your glovebox, maybe I should add a note in the user manual!
22nd Oct 2014 5:47pm |
My IID never leaves the door pocket, unless it's being used |
22nd Oct 2014 6:41pm |
