Home > Technical (L322) > Engine Rattle on Start-up
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I noticed, last winter,when the car had not been used for a few days that there was a "rattle" for just a couple of seconds on starting. I put it down to maybe the timing chain adjuster sticking and then freeing off. No hint of it when being used often and in the summer months.
I came to use it a few days ago after it had been sat for a couple of weeks and the start-up rattle manifested itself again. This time I gave it closer attention. I revved up to over 3000 rpm and the rattle reappeared with some urgency. Went over 5000 rpm and it suddenly disappeared and has not come back.
I have a feeling that there is a loose nut or bolt in a cowling which occasionally comes into contact with a pulley, or such like and then gets flung into a tight space somewhere and then gets ejected back into wherever the pulley is, when everything has a chance to cool right down.
Everything else to do with the engine, apart from an annoying minor water leak, is OK and I have done over 5,000 miles since the rattle first occurred!
Anyone had anything similar? Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #286435 14th Oct 2014 4:57pm
ebajema
I'm wondering if it has to do with the chain tensioner of the cam chain. It may have been a bit "stuck" and the high revving loosened it up again. Although the original AJV-8 has some issues with the cam chain, our versions should have the improved version without issues. MY 2010 5.0 SC Galway green and sand interior!!
Post #286507 15th Oct 2014 2:35am
Does it have hydraulic tappets??, probably does..... if it does, it's because the oil will drain from them if left standing for a while and it will take a some time for the pressure to build up after you start it, I wouldn't rev it up if I were you, just drive it normally until it goes away... Pete
-Click here for Thread-
Post #286509 15th Oct 2014 6:22am
appj62
Definitely sounded like a loose nut/bolt/screw. I was not daft enough to rev it high from cold. I did have a belt changed last year (summer) not long after I had purchased the vehicle.
I will keep a weather eye/ear out to see if there are any other unusual noises that would indicate if water pump pulley or alternator have fallen off Laughing Previous cars:
Galaxy 2001-2007
Fiesta 1984 - 1987
Post #286515 15th Oct 2014 8:12am
miggit
I was going to say tappets too, especially as it goes when the revs are raised, that would be the oil pressure going up and re-filling the tappets. Might be an idea to have a listen under the bonnet on start up to try source the general location of annoyance before you rip the engine apart !! Yesterday I couldn't spell Engineer... Today I are one!
Post #286713 15th Oct 2014 10:50pm
appj62
Rattle was originally on start-up. Last time it happened though, engine was warmed up and I dabbed the throttle to take it above 3000 rpm. The rattle returned with more urgency but then disappeared for good, when I took the engine above 5000. I won't know for sure until mid- November, when the car will have sat doing nothing for a fortnight, whilst I am at work! Previous cars:
Galaxy 2001-2007
Fiesta 1984 - 1987
Post #286784 16th Oct 2014 9:45am
